Does this look particularly "noisy" to you? at DVinfo.net
Canon EOS Full Frame for HD
Old May 3rd, 2011, 05:28 PM   #1
I shot this test.
ISO 250 at f4.5.
I know that the 5D footage is heavily compressed, but this just looks "noisier" and more pixelated than it should to me, and more so than other footage I've seen online.
Especially if you go to full-screen mode and look at the darker background (especially to the right of the "subject").
I imported it into Final Cut as Prores (HQ) using the EOS movie plug-in, and exported it as H.264 (although, it looks this noisy/pixelated in Final Cut pre-exporting)
Maybe it's just a function of the in camera compression?
I just want to make sure there isn't something wrong with my camera or that I'm not doing something wrong in the import process.
Thanks in advance.
Todd Sheridan is offline   Reply With Quote
Old May 3rd, 2011, 05:35 PM   #2
Re: Does this look particularly "noisy" to you?
Todd,
I'll jump in for what it's worth. I see 2 things here that would make your shot noisy. Number one, it is underexposed and underexposed images are going to show more noise. Also 250 is one of the electronic ISOs which generate more noise than it's higher counterparts, so if you were at 320 you would have less noise than 250. Good luck, I think your camera is fine.
Bill
Cinema Couture
www.cinemacouture.com
Bill Grant is offline   Reply With Quote
Old May 3rd, 2011, 05:42 PM   #3
Thanks.
I have looked at other "low light" clips online, where parts are definitely underexposed, and I just don't see the same level of noise.
Old May 3rd, 2011, 06:15 PM   #4
Avoid shooting at anything except 100, 160, 320, 640, and 1250. They have the lowest noise. 100 is actually a bit noisy, but is sometimes needed in bright situations.
Jon Fairhurst
Old May 3rd, 2011, 06:19 PM   #5
Interesting. I had never heard this regarding specific ISOs being more or less noisy than others,
I had always just assumed the lower the ISO, the less noise.
Thanks guys.
Old May 3rd, 2011, 06:58 PM   #6
I would add 2500 to that list. Easy. Clean as a whistle.
Cinema Couture
Old May 3rd, 2011, 07:21 PM   #7
I will have to stop asking questions and just do some tests myself, but are you saying that 2500 is cleaner than 250?
Seems hard to believe.
Old May 3rd, 2011, 07:23 PM   #8
Check out the chart that can be found on this page:
Optimising your 5D Mark II for filmmaking-kriskoster.com | kriskoster.com
Jon Fairhurst
Old May 4th, 2011, 01:34 PM   #9
nope, I'm saying I use 2500 in addition to those other ISOs and it is very clean. Now, I'm coming from a video camera background where 6db of gain is unuseable. 320 is cleaner than 250 though.
Bill
Cinema Couture
Old May 11th, 2011, 11:22 PM   #10
Hi Jon, I thought that the lower ISO had the least amount of noise. So if you go up to 1250 wouldn't it get pretty noisy.
Osman Flique is offline   Reply
