Tokina 16-28mm f/2.8?? at DVinfo.net
Canon EOS Full Frame for HD
Old June 26th, 2011, 04:13 AM   #1
Anybody use this lens? I only just heard about it while trying to figure out whether to dig deep and buy myself the 16-35mm or save a bit and get the 17-40 4L (Save to get myself a 35mm prime).
Anyone know, use, want to give me this lens?
Jason McDonald is offline   Reply With Quote
Old June 26th, 2011, 10:02 AM   #2
Re: Tokina 16-28mm f/2.8??
its not compatible on a full frame camera like the 5D... Although I hear its a great lens if you have a 7D.
Red Epic available for rent, starting at $500 per day, Scarlets, and Lenses available too. rentals.maddalenamedia.com
Louis Maddalena is offline   Reply With Quote
Old June 26th, 2011, 12:59 PM   #3
No Louis, this is a full-frame lens. Perhaps you are confusing it with the 11-16.
Jason, I have been shooting with this one for about a month and am very happy with it. I have the previous series Tokina zooms (28-80 and 80-200) and while they are softer than my Zeiss ZE's, they color match well and have the hard stops for focus that make them preferable for me than the Canons. The 16-28 is much sharper, has very little distortion and overall is a great lens, especially if you can work at a 4 or greater. This is the first in a series of new Tokina full-frame zooms and I look forward to replacing my older gen versions as the others emerge.
Charles Papert
www.charlespapert.com
Old June 26th, 2011, 07:11 PM   #4
Do you think you can through up some sample video? I've searched but nobody seems to have any.
Old June 26th, 2011, 07:21 PM   #5
ummm...don't think any of the projects I've been using it on are clear to share at present. Maybe (no promises) I can roll off a bit tomorrow when my gear is returned from a job. What exactly would you like to see demonstrated?
Charles Papert
Old June 26th, 2011, 08:23 PM   #6
Charles,
How do you use ND filters with this lens? It looks like it can't take any filters on the front of the lens. Are you limited to using it with a mattebox?
Daniel Weber
Daniel Weber is offline   Reply With Quote
Old June 26th, 2011, 09:13 PM   #7
Yes, I use it with the O'Connor O Box and 4x5 filters, which do not vignette.
Charles Papert
Old June 27th, 2011, 10:24 AM   #8
Any video you have time to take, just showing it at 16mm and 28mm, something inside so you don't use the mattbox or sometime late in the evening.
Just curious as to how it holds up
Old June 27th, 2011, 03:14 PM   #9
Ahg, I apologize! I have been quite overrun and probably shouldn't try to help anybody when in this state lol. That is indeed what I did. Thank you for correcting my mistake Charles!
Old June 28th, 2011, 10:07 AM   #10
I can't quite figure out which one I want:
or
Canon 17-40mm f/4 L
The Tokina has 2.8 all the way through. But no filters to protect the front element.
The Canon can got to 40mm and accepts filters. It's also Canon glass...wish there was more out there on the Tokina lens.
Old June 28th, 2011, 10:18 AM   #11
For me, filters on a wide are a necessity. Timelapses generally use wides and if you want smooth motion, you need to be able to use an ND filter.
Jon Fairhurst
Jon Fairhurst is offline   Reply
