Jerky footage with 1DMK4 - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old November 27th, 2011, 06:55 PM   #16
Re: Jerky footage with 1DMK4
DSLR footage is an H264 quicktime file. Post up your shot you are talking about and we can comment better.
Justin Molush is offline   Reply With Quote
Old November 27th, 2011, 10:37 PM   #17
It's h.264 and not AVCHD, but that's splitting hairs. The bottom line is that, like AVCHD, it has a long-GOP (group of pictures) structure so it's a poor editing format. I highly recommend Cineform Neoscene. Then again, CS5 handles Canon MOV files pretty well on a powerful computer.
You might try looking at the frames one at a time while measuring the motion. It's possible that the camera dropped some frames if your card couldn't keep up. It's also possible that your computer can't keep up. Frame by frame analysis would prove it out - especially if you find that you get a duplicate.
Jon Fairhurst
Old December 15th, 2011, 02:55 AM   #18
Thought I'd just say I no longer get the jerky footage. I followed advice and always shoot at 1/50th, and keep the movement in tracking shots very slow (and speed up in Premiere pro if needed). I have also found that Premiere Pro's Frame Blend adds that last bit of smoothing.
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old December 22nd, 2011, 03:27 AM   #19
I used to get jerkiness on an early firmware version but with subsequent updates it went away ages ago, and I haven't had to worry about it since. Then recently I was trying a mini jib and found jerkiness evident in those shots. The shot was one that dropped diagonally into a room scene at a moderate speed.
As always, manual settings, 1/25 shutter 50 - then something like f4 and a moderate iso of 320 I think it was.
I reinstalled the latest firmware update and will check it out again when I get a minute.
Avey
theactionhouse.com
Wayne Avanson is offline   Reply With Quote
Old December 22nd, 2011, 01:41 PM   #20
It's that "moderate speed" that can get you. I've seen the same on some of my jib shots that I've done that weren't tracking anything. I was just showing the space.
According to the ASC tables, panning should take 7 seconds or more (roughly) from edge to edge. You can go faster when tracking a person or vehicle. And (aside from rolling shutter issues), you can whip pan. A whip is abrupt enough that the move is disorienting, so the judder isn't noticed.
What I've learned is that I need to be more patient with non-tracking jib shots. If it will take too long or doesn't have high enough energy, I can add jump cuts in post. And if one values smoothness over sharpness, consider 1/30 or 1/25.
Jon Fairhurst
Jon Fairhurst is offline   Reply
