Canon EF 300mm L, f4 & f2,8 at DVinfo.net
Canon EOS Full Frame for HD
Old October 9th, 2012, 11:32 AM   #1
I have read the reviews, know the price difference, but have not used either lens.
Yes, I want sharp and the ability to use the 1.4x or 2x.
Has anyone had experience with either lens or both?
Paul Cronin
www.paulcroninstudios.com
Old October 9th, 2012, 02:28 PM   #2
Re: Canon EF 300mm L, f4 & f2,8
I haven't used either, outside of a tradeshow booth, but I used to own the 200/2.8L II and a 2x Extender. With that combo, autofocus became very slow and the images were noticeably softer than with the naked lens. If you go with the f/4 lens, then I don't believe that AF will even work with the 2x Extender and you'll need a lot of light for the f/8 combo. I'd definitely not go past 1.4x times with the f/4 lens. Even with the f/2.8 lens, the 2x Extender might soften things more than you like.
I used the Mk II extender. Maybe the new, Mk III is sharper and supports improved AF.
Jon Fairhurst
Old October 9th, 2012, 03:21 PM   #3
Interesting I have heard by two photographers I know that the new 300 2.8 and 2xIII work like a dream.
Agree the f4 would not be worth extending.
Paul Cronin
Old October 9th, 2012, 04:17 PM   #4
Originally Posted by Paul Cronin View Post
Interesting I have heard by two photographers I know that the new 300 2.8 and 2xIII work like a dream...
That may very well be. I owned the 200L II and 2x II before the III was released. The 300/2.8 starts out sharper than the 200, and Canon says they improved the Mk III extender sharpness and quickness.
Still, if I had to do it again, I would have bought the 1.4x extender, rather than the 2x - at least for the 200L and the Mk II generation of extenders.
But it really depends... If you are shooting sports photos, you want quick AF and can crop, so 1.4x might be the right choice. If you're shooting video, AF doesn't matter and cropping isn't an option for an HD output, so 2x is fine if f/5.6 isn't too slow. Also, the sharpness isn't as critical for video as it is for photos. I wanted both. ;)
Jon Fairhurst
Old October 9th, 2012, 04:28 PM   #5
I think the extender is a second thought and one I would not even consider until I choose the lens. 1.4x could be fine. It would be used 90% for stills on the MKIII in demanding conditions. And it would be used on the C300 in rare locked down shots.
I need to find out how much better the f4 is then the older f2.8 and newer f2.8.
Most Canon still shooters I know in my industry say the 2.8 is the sharpest lens Canon has made for DSLR. So how much better is the new on then the old 2.8. Big price difference.
Paul Cronin
Old October 9th, 2012, 05:24 PM   #6
Here are the head to head comparisons (mouse over to see the 2nd lens). First resolution...
Canon EF 300mm f/4.0 L IS USM Lens Image Quality
Canon EF 300mm f/2.8 L IS USM Lens Image Quality
Canon EF 300mm f/2.8 L IS II USM Lens Image Quality
And then vignetting...
Canon EF 300mm f/4.0 L IS USM Lens Vignetting Test Results
Canon EF 300mm f/2.8 L IS USM Lens Vignetting Test Results
Canon EF 300mm f/2.8 L IS II USM Lens Vignetting Test Results
As I see it, they're all killer lenses. Me? I might go for the older f/2.8.
The f/4 performs well, but the other two are better at f/4. No surprise. I like speed, so I'm drawn to the faster glass.
The f/2.8 lenses both rock, but the II is freaking amazing in the mid an corner areas. Geez! That said, I wouldn't be buying that lens for f/2.8 shots of landscapes and images of detailed walls. I'd be shooting sports, wildlife, and/or people with a large aperture. And for those shots I want the subject sharp and the corners will be a DOF blur. And who needs sharp corners for that? If I'm shooting for corner to corner detail across a canyon, I'm stopping down to f/8 and any of the lenses will sing at that setting.
According to the review...
Canon EF 300mm f/2.8 L IS II USM Lens Review
...the newer lens gives better IS, but the older lens does as well if not better for AF.
And, yes, the newer lens with the 2x Extender III looks to be magnificent. I might stick with 1.4x for the older lens, but 2x looks to be amazing with the new glass.
As for minimum focus distance, the f/4 lens wins hands down, so it might be the best closeup lens. The older f/2.8 is pretty weak for minimum focus distance.
All of the choices look to be excellent. The new f/2.8 is other-worldly. But do the sharp corners, better IS, and shorter MFD matter? It all depends on what you shoot.
Fortunately, there is no bad decision here - especially since top glass is more stable than government bonds. :)
Jon Fairhurst
Old October 9th, 2012, 07:13 PM   #7
Thanks Jon for taking the time to put together the info. I am done for the day and on the road tomorrow. Will check it out in more detail tomorrow evening.
OK I am still waiting on a render.
I agree with your comments most of the time the edges will be blurred. And speed is great when i shoot at dusk or sunrise. So now to try them first hand.
I think the f2.8 version could be found for 1/2 the price of f2.8 II.
Paul Cronin
Old October 9th, 2012, 11:10 PM   #8
Paul (OP):
I am not sure the reason you are buying a 300mm lens. Let me share a few comments & they do not apply, so be it.
1. I have a 400mm F5.6 lens I use mainly to shoot surf photography. I considered buying the more expensive 400mm lens (bigger aperture) or the 500mm lens. When I checked the actual clarity of each lens, my lens performed well & cost a fraction of the others. After owning & comparing my lens to the ones I lusted for, I realized I was happy I ended up not laying out over 6 grand for soomething that does only slightly better at what I use it for.
2. I shot my 400mm for an hour, then the next hour with my friends 500mm F4 shot the same surf spot. At times I used my 1.4 extender. The bottom line is the more I shot with his expensive 500mm lens, the more I realized the cost & weight (hassle when traveling) was not as wonderful as I thought it would be. Cropping with my 400mm lens did not reduce the quality of the photo significantly enough to merit paying 5X as much for the lens 500mm lens IMO. If he traded me straight across, of course I would take his but not sure it is worth even $1500 more to me vs the $4500 more it cost then my 400mm.
3. When using a 1.4 extender, the auto-focus is too slow IMO. To be blunt, when shooting far away like I do, I found auto-focus ruins as many photos as it helps simply because the light reflecting off the water trips up the auto-focus by focusing on a reflection out of focal range of my subject. When manually focusing, I can keep the focus correct from where the surfers take off & end their ride/kick out. Basically shooting in manual focus is not a big negative for me.
4. I have used my 2X extender & of course the reduction in quality is noticeable. The 1.4X is fine, 2X is a reduction I do not prefer to use. What I found out is when you get to the point of needing 800mm lens, the 500mm comes up a bit short as well & now you are dealing with something like a $8000-$10,000 lens (have not checked the prices lately). For me, at this point, better to take my 70-200mm lens, throw my 1.4 extender if needed & shot from a boat, get a better angle vs using a lens that needs to be 800mm or crop it so much. Yes, I might have to pay $20 a day to shoot from a boat but better to pay $20 than a massive amount for a 800mm lens etc.
5. My friend that let me use his 500mm lens is a professional photographer & shoots 1300 photos a day at this surf spot & then sells them to wanting surfers. I am certain the difference in a 400mm cropped photo vs a 500mm photo would not make a difference in who bought a photo & besides those that simply love to debate about lens would care about the difference between the two.
6. I think there is a bigger difference between the Canon 100-400mm lens vs my prime 400mm lens than the 400mm f5.6 I own vs the 500mm prime f4 I shot with. You will find the 100-400mm lens is very soft around the edges compared to a prime.
7. Regarding surf photography, the F4 vs f5.6 is more about light then clarity IMO. Even when it is overcast in Calif & 6am., I can shoot at over 1/1000 of a second & moe often shooting at over 1//2000 which is more then fast enough. The worse I have to do in low light situations is push my ISO up to 400. I really cannot justify paying so much more for 1 f stop.
All of this makes me feel that unless you are shooting for national geography, are obsessed with having the largest aperture for bragging rights, or simply money is no issue, the more expensive 400mm/500mm lens are not needed.
I enlarge photos 20x30 all the time, they look great. My main point is everything in life is a compromise be it size & quality of lens, size of aperture, & cost of equipment vs need for quality. Everyone varies in needs & desires. For me, you can see I compromised with a 400mm prime @ f5.6 vs a 500mm prime F4. The bottom line is if you are happy with what compromise you made, then you made the right choice. I have found the person shooting the photos & their ability to capture the surfer at the right time etc is much more important than the f5.6 400mm vs f4 500mm issue.
Again, I do not know your needs so some or all of this maybe worthless information.
Jeff Wisener is offline   Reply With Quote
Old October 10th, 2012, 04:36 AM   #9
Jeff,
Thanks you for taking the time to response, that is the first hand input I am after.
My shooting is on the water boat to boat and in the helicopter shooting boats, just like most of my video. And even at times shooting surfing from the shore. A lot of time I can get away with the 70-200 but most of the time I feel the 300 would be perfect when the boats are big or when there is a fleet and you can't get close enough.
Your points about f2.8 vs f4 for me are spot on what I am dealing with on the water. I bet know one would know the difference if I shot with f4 or f2.8 since there is alway light and reflection only adds to the light. Also the 5D MKIII has a great useable ISO range.
Makes sense with the AF not working well with 1.4x. I live by manual focus with my video and have no problem doing that for long stills. Are you using the II or III in the 1.4x extender?
Off to make the donuts for the day. Thanks again Jeff your post has been very helpful.
Paul Cronin
Old October 10th, 2012, 01:16 PM   #10
OK back from Rule Camera in Boston checking out my rig choice for the C300 and buying a few items.
Then I went to Andrew at the rental desk who has helped me out for years and knows his stuff, as they all do at Rule. His suggestion is buy the new 70-200 f/2.8L II and the 2x III extender. He said the combo is great and they do not rent the 300 due to cost of lens and how few times they will rent it.
Well I am going to buy the 70-200 anyway so I will see if I can rent the 1.4x III and 2x III to check them out.
Be nice to try the 300 f/4 at the same time if possible. Andrew did give me a rental house local that has all of them, so maybe a long weekend with nice foliage and both cameras.
It will be a week or so but will post what I find out.
Paul Cronin
Old October 11th, 2012, 07:41 PM   #11
I have the Canon 300mm F4 IS lens and it is very sharp. I was surprised how nice the lens was considering it only costs about $1400. The IS works very well when shooting in low light. I have also used it on my 5DM3 when shooting video and it is wonderful for interviews when you really want the background to drop off.
Daniel Weber is offline   Reply With Quote
Old October 12th, 2012, 07:02 AM   #12
Daniel appreciate the input.
You say the lens is sharp when shooting video. Do you use it for stills often? Next week I get a chance to use a buddies 300 f/4 so I should answer my own question but always nice to have owners input.
Paul Cronin
Old October 12th, 2012, 08:33 AM   #13
Here is an image I took with the 300mm f/4L IS lens plus the 1.4x extender. The exif data shows a stop of 7.1 but considering the extender adds a stop the lens itself is only stopped down to about f/5.
http://www.LandYachtMedia.com
Old October 12th, 2012, 08:43 AM   #14
Thanks Chris,
Which 1.4x extender is it the I, II, or III?
Paul Cronin
Old October 12th, 2012, 08:46 AM   #15
It was v2.
Chris Medico is offline   Reply
