-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Dust on lense (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/10425-dust-lense.html)
Alex Geschke June 2nd, 2003 10:32 PM
Dust on lense
Minor problem. I use a UV filter like everyone else but somehow I acheived depositing 2-3 small dust particles to the camera lense.
The particles are visible to the naked eye but are not visible upon video output.
I know about lense paper and air brushes ect., but I wanted to get some suggestions before I begin this most delicate procedure.
Frank Granovski June 3rd, 2003 12:08 AM
Blow real hard, once or twice, take a look, and blow one more time for good measure. Then, with a lens cleaning cloth in one hand, and the cam in your other, breathe hard to fog it up a bit---if you're over .07, all the better. Finally wipe gently a few times so it becomes crystal clean. Now screw the filter back on. (Make sure you follow this procedure on the inside of the filter just before you do the lens.) Lastly, clean the outside of the filter using this time honored technique.
Tustin Larson June 3rd, 2003 12:29 AM
If after you try Frank's techiques, and they are still there... call Canon Service Center.
Thanx,
Don Palomaki June 3rd, 2003 04:19 AM
When you blow real hard you also send out some spit, not great for lenses. If you are fussy about that sort of thing, better to use compressed air (or other suitable gas) in a can, sold at most good photo shops for that specific purpose.
Graham Bernard June 3rd, 2003 04:32 AM
Anybody suggesting a "wet" opthalmic lens cleaner here? - If it works for my spectacles, will it work/benefit from such a solution? Any drawbacks?
Grazie
Michael Buendia June 3rd, 2003 01:15 PM
this is my 2 cents:
get yourself a mini lens pen (brush), canned air or a hama air bulb, peca pads or opticlear cloth & formula mc (cleaner). you can find most of this @ http://www.2filters.com/.
try to blow out as many particles as possible. follow this by brushing the lens area in a circular motion. apply a small amount of formula mc on a cloth and in a circular motion clean it from center to edge and it will be good as new!
good luck.
Alex Knappenberger June 3rd, 2003 01:21 PM
I've been using these eye glasses pad cleaner things to clean my lens...they work pretty well.
Frank Granovski June 3rd, 2003 01:35 PM
I didn't say spit when you blow. :)
Don't just put a cleaning cloth to the lens, because with rubbing, the particles might scratch the lens. If you're not heavy winding, to put this time honored technique to good use, do use a bulb/brush thingy, or a can of compressed air---then apply the lens cloth or lens tissue (gently). However, if you're using a can, keep this can of compressed air well away from your precious lens.
Ryan Krga June 3rd, 2003 01:54 PM
I have an LCD cleaning clothe that is used for getting finger prints off of the LCD screen. One day I tried it on one of my older cameras just to experiment and see if it would get the job done and it worked great.
Don Palomaki June 3rd, 2003 05:32 PM
An issue with generic glass cleaning solutions and cloth or tissue is that they may harm the coating on a lens or leave a residue. Best to only use materials intended for photographics lenses. As noted clean of fhe big chunks first using a lens brush or clean, dry air. Use solution only as a last resort.
