Real World Experience of VL-3 Lamp? at DVinfo.net
Old June 22nd, 2003, 04:20 PM   #1
Old Boot
Title says it all.
I'm considering something to give a bit of "umph" to a scene.
Grazie
Old June 22nd, 2003, 05:46 PM   #2
I didn't think it gave much umph at all. I went with the VL-10i instead. This can also be used slightly off camera for a little more realisti light. I figure that I can also use a mirror to bounce it up if I want a little less harch light.
Joe Sacher is offline   Reply With Quote
Old June 24th, 2003, 02:06 PM   #3
Videolight
After having tried both the VL-3 and VL-10Li, I would recommend the VL-10Li. Or maybe even a more powerful light.
Old June 24th, 2003, 02:46 PM   #4
VL3 is good to create a "catch light" in the eyes of your subjects assuming they are fairily close to the camera. I have used it with good success when doing outside work with interview subjects.
It won't light up a room thats for sure but it is handy for when you just need a bit of extra light right in front of the camera.
Cheers;
Eric
P.S. Search on VL3, there are a few good threads in here that I used before I decided to buy mine.
Eric Gutknecht is offline   Reply With Quote
Old June 24th, 2003, 03:16 PM   #5
Old Boot
I've seen the Light!
Thanks Eric, Trond & Joe.
Bought the VL3 - haven't used it on a project yet. Will have a chance soon. Have compared this to a VidPro's Sony fill light - VL3 does do some good work up to about 1.5 / 2 metres - that's about it. This could be all I need. I did read all the vl10 AND vl3 posts. Knida got influenced by Chris Hurd's comments. Basically I don't want to "scare" poeple off at a wedding - just a bit of coaxing - yeah?
Eric you got it about right for me too: "It won't light up a room thats for sure but it is handy for when you just need a bit of extra light right in front of the camera."
Thanks again chaps,
Grazie
Old June 26th, 2003, 11:06 PM   #6
You want to see what could does a VL3 in a dark Club? Easy:
http://marc5532b.free.fr/file/without_vl3.jpg
http://marc5532b.free.fr/file/with_vl3.jpg
Same settings on the 2 images:
Manual mode
S: 1/25
F: 1.6
0 dB gain
Marc Martin is offline   Reply
