MA-300 vs. Beachtek DXA-4P - Page 2 at DVinfo.net
Old October 14th, 2003, 04:32 AM   #16
I need the DXA-6, apparently
Thanks, but the DX-2 thingie only had ONE XLR input (my Rodes are each the same XLR-type connector).
I found out that the DX-4P required external phantom power, so that wouldnt work, and the XLR-BP Pro website said it was passive and worked for 'externally phantom powered' mics.
So, i found the DXA-6 which is two XLRs, plus two phantom powered channels.
thanks anyway,
glenn
Glenn Miller is offline   Reply
