XM2 and Sony VCLHGD 1758 at DVinfo.net
Old November 20th, 2003, 03:57 PM   #1
Help please with a current problem.
I have an XM2 that I use for wildlife video and get some very good results, however, sometimes I could do with an increase in the zoom range and have considered adding the Sony 1.7x telephoto adaptor. Has anyone tried this and was it successful? I want to retain the image sharpness of the XM2 and wondered if this adaptation would ruin this.
Any thoughts or experiences?
Chris.
Chris Gaston is offline   Reply With Quote
Old November 24th, 2003, 09:45 AM   #2
RED Code Chef
I think there were some other adapters people used. Try a
search. Don't think I've heard of the sony adapter before.
Rob Lohman, visuar@iname.com
Old November 25th, 2003, 01:25 AM   #3
Hi Rob, many thanks for the suggestion. Since posting the question I discovered a number of comments regarding teleconverters and it appears the Centuary Optics DS-20TC-58 is considered the best option for quality, although a bit expensive. All teleconverters, I am told, contribute to some degree of colour fringing at the full extent of the zoom, but with a x2 converter on the XM2 there should be plenty to spare and therefore should not cause too many problems.
Regards,
Chris.
