Recording in LP mode at DVinfo.net
Old June 18th, 2004, 07:20 AM   #1
Recording In LP Mode (GL2 Cam)
When I record in LP mode on my GL2; I have streaks of digital lines appear in the video. The manual suggest that for important recordings; record in SP mode. Do anyone else have the same problem with recordings in LP mode.
Also, where can I find Mini DV tapes longer than 80 min since it seems I can't use LP mode on my GL2.
Thanks.
Stephen Shabazz is offline   Reply With Quote
Old June 18th, 2004, 01:23 PM   #2
RED Code Chef
Please use normal sentence constructions in the future when
posting. Every word should not be capatalized in a sentence
and reads hard. I had to edit all your words.
Avoid LP recordings or tapes over 60 minutes. Tape systems are
very fragile and you don't want to challenge faith when recording
precious footage. Tape is cheap, buy more tape.
If you need more recording time than 60 minutes in one recording
then use two camera's or get a direct-to-disk recording system.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
