Just got my Gl2 - Page 2 at DVinfo.net
Old September 4th, 2002, 12:48 AM   #16
Moderator
Hi John,
The one that I have is labeled as the TWIN V102, however, if you look it up on the Sunpak site at [ http://www.sunpak.com/sunpri.html ], the Sunpak catalog # for the TWIN V102 is "ACC-M1013-01" - which is described on their site as the Twin V102 Rapid Charger. This is the model I have.
I did a search on the web for the TWIN V102, and nothing comes up - however, when I search for the ACC-M1013-01 catalog #, I get it for sale at various sites such as [ http://www.batterymart.com/merchant2/merchant.mv?Screen=CTGY&Category_Code=digitalcamera ] for about 39.95. If you look closely at the picture of the unit, you will see the word "CANON" in each battery compartment - just like it says on the model I have.
I'm 99.97837653% positive that this is the beast!
Keep in touch,
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old September 4th, 2002, 11:07 AM   #17
Thanks, Don
Thanks, mucho. The Sunpak web site leaves much to be desired. But it does look like the one you mentioned will work.
Thanks again, John V.
John VVV is offline   Reply
