GL-2 not recognized by Windows XP - Page 2 at DVinfo.net
Old February 20th, 2005, 11:08 PM   #16
Here is a nice piece of information that I didn't see so far on this board , it came from a reply that I got on motherboard ...board:
All the voltage are within their rated specs...
Normally, all the voltages should not go 10% above or 5% below of their given values.
the + 12 V is a bit too high, but it should not sent devices into selfdestruct yet.
Mostly there is an SMD fuse embedded in each USB / Firewire port.
So if its blown out, simply that single port or array of ports of the same type just stopped to function.
A PCI --> Firewire card should bring the easy fix.
Firewire does use 5 Volt, just like USB and PS/2.
Victor.
Hope it will enlighten some
Phil
Still lost in Vice city
My website: www.production24fps.com/english.php
Philippe Gosselin is offline   Reply With Quote
Old February 21st, 2005, 04:02 AM   #17
RED Code Chef
The best way to prevent blown ports (on your camera) is to make
sure it is turned off before plugging/unplugging. If you really want
to be safe shutdown (or standby/hibernate) your computer as well.
Rob Lohman, visuar@iname.com
Old February 22nd, 2005, 12:16 AM   #18
Well here is the latest ,
I rented a small handycam so i could at least capture what I shot last friday and guess what , as soon as I plugged the firewire cable in the camera (and turned the power on AFTER plugging it in) XP saw it instantly so it is pretty obvious what the problem is.
I will keep this post alive just for the sake of proving that one will never hotplug any firewire device again.
Thank you Mac
(I am so mad right now I am screaming)
Phil
Old February 25th, 2005, 05:29 PM   #19
Hi all,
Well I just got back from the shop where they are suppose to fix the problem. The tech is almost 100% sure that the whole board is busted and will need replacement. We are talking about a 600$ cnd repair here.
Obviously this is utterly unacceptable. I could buy a fine second-hand handycam for 300$ that will let me capture and be a second camera as well.
By the way is there any loss of quality when capturing from another device than the one used to shoot the footage. I don't how it could but I am asking nonetheless.
Next monday the tech from the shop will talk with Canon to smooth things out and reduce the cost of needed parts. Will let everybody know of the tragic end ...or not. :)
Old February 26th, 2005, 06:34 AM   #20
RED Code Chef
If the cheap camera is a DV camera the quality will be 100% the
same for capture. HOWEVER, make sure you test the camera you
are going to get to make sure it can READ your GL2 tapes!
Due to slightly different tape systems and head alignment (which
can change with use!) not every camera can read tapes from
other cameras etc. A full blown DV deck would be saver in that regard.
Old March 5th, 2005, 12:20 PM   #21
I recently had a simlar problem where XP Pro (w/SP2) no longer recognized my GL2.
It turns out that if you have your TAPE/CARD switch, located directly above the [record] Start/Stop button, set to CARD, XP will not recognize your GL2. Switching it back to TAPE fixed the problem for me.
Ming Dong is offline   Reply With Quote
Old March 6th, 2005, 06:18 AM   #22
RED Code Chef
That's interesting to know Ming, thanks!
