Shallow depth of fields examples at DVinfo.net
Old September 30th, 2002, 04:41 AM   #1
Bassbooster
Posts: n/a
Hi,
Granted, a GL-2 is not a 35mm camera and you can't get the same kind of control over DOF.
So the question is, what can you reasonnably expect to get from the GL-2 in terms of shallow DOF?
Surely, if you subject is really close, you can get the background to be blurry.
But is it possible at least to be 2meters away from a subject and manage to get the focus specifically on it? If anyone has some examples, I would be interested.
Old September 30th, 2002, 08:28 AM   #2
Warden
You might want to read this first http://www.dvinfo.net/conf/showthread.php?s=&threadid=3926 and if you have questions, post back.
Jeff
Jeff Donald is offline   Reply
