Advice for shoot at DVinfo.net
Old November 13th, 2005, 06:43 PM   #1
Advice for shoot
I’m prepping for a upcoming shoot and am considering locations, and was wondering if anyone can give a few tips on this. This is a sports medicine video on stretching, and our first in-house production. The last video was shot inside our office, so it was uncomplicated as far as lighting etc. Am I crazy to shoot this outside if I’m new to video? I found a great location on the water on a dock, but it is direct sunlight. The video has about five minutes of on camera talking; the rest is just shots with voiceover. I was thinking we could shoot it early morning with nice lighting. We have a LOW budget for this video so the equipment we have is it: Cannon GL2, Sennheiser EW100g2 mic., of course tripod. I’m new to setting manual settings on the camera but am getting better. I know there will be mistakes, but any advice would be appreciated. Thanks in advance.
Tim
Tim Agnew is offline   Reply With Quote
Old November 14th, 2005, 08:21 PM   #2
Fred Retread
With the GL2 and the Senn, I think you're in pretty good shape for video and audio.
Outdoors in particular, where there can be distracting features in the background, I would go for as shallow a depth of field as possible. I'd open the aperture to 1.6, and use the built-in neutral density filter and/or the shutter speed to adjust the exposure, and preferentially move the camera back and zoom in. (As you zoom in, 1.6 may not be attainable--the aperture automatically closes a few stops).
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old November 15th, 2005, 05:35 AM   #3
Outdoor lighting can be harsh, especially if you have direct sun, you probably will need fill light, maybe use reflectors?
If you can, go to the location a few days in advance and do a practice shoot to assess lighting issues at the intended times of day and possible solutions.
Early morning light can change quickly as the sun rises, and if you are editing from multiple takes over a period of time it may be obvious in the final print.
dpalomaki@dspalomaki.com
Old November 15th, 2005, 08:42 AM   #4
So I'd do better to shoot it all at once- even with the changing light of morning (or dusk). Could you all direct me to where to get reflectors and are they costly? Also- what about battery juice? Is there a battery that lasts longer than the one that came iwth the GL2? Seems like I'd run out of juice on a long shoot. Your help is much appreciated.
Tim
Old November 15th, 2005, 09:24 AM   #5
lighting
Tim,
I do 90 % of what I shoot outside. The prior posts are all on the money.
If you shoot near the water and it is possible to be in the picture I would use a polarizing filter so that it will cut the glare off of the water. It will also require the apeture to open up a bit more and also facilitate the depth of field issue.
Gus
Old November 16th, 2005, 05:50 AM   #6
Most photo/video supplies houses that serve professionals carry reflectors. Try Markertek for one, and see ads in trde press/magazines.
The November issue of Videomaker has some info in the lighting section on using reflectors that might be of interest
Many folks hare having succes with after market batteries, Lenmar and Sunpak are a couple brands I've used.
Don Palomaki is offline   Reply
