Dust in lens at DVinfo.net
Old January 30th, 2003, 02:44 PM   #1
Dust in lens
I just bought a new GL2 (yippie!) and noticed there is a large piece of dust inside the lens. Does anyone know if there is a way for me to get this out? Otherwise, I'll return it for a new one.
Also, I was informed the GL2 will accept the same batteries as the XL1s where I use Lenmar batteries. So, can I safely use these Lenmar batteries in the GL2?
Thanks much!
Ron
Ron Lucas is offline   Reply With Quote
Old January 30th, 2003, 08:20 PM   #2
About the dust -
Are you sure it's INSIDE the lens? If so then that's definitely a return - don't even mess around there.
Peter Moore is offline   Reply With Quote
Old January 30th, 2003, 08:43 PM   #3
Yeah, it's inside. There doesn't seem to be any way to get to it. It's below the surface of the lens sitting on another piece of glass down there. Oh well, I contacted the reseller and their getting me another one. Just got it today, but love it!
Ron
Old January 31st, 2003, 12:02 AM   #4
Outer Circle
Dust/dirt is a bummer with any lens. It's always one of my concerns with buying used camera lenses. Another thing to look for is nicks, scratches and flaws in the surface of the exposed glass.
Old January 31st, 2003, 09:47 AM   #5
Sounds very familiar! I just received shipment of a replacement GL2, and I am sending my original back for the same reason (if you're wondering, I had to do a double charge). There is a little white spec inside the lense.
Regardless, I am more impressed every day with this little camera.
Brad Higerd is offline   Reply With Quote
Old January 31st, 2003, 02:14 PM   #6
Hello, I have the same problem
My camera had a problem with the lens and they repairt it, then they sent it back to me and now i have dust insight
I`ll think i call them monday and sent it back.
erwin kolman
Erwin
Erwin Kolman is offline   Reply
