Gl2-expensive issues at DVinfo.net
Old February 26th, 2007, 03:36 PM   #1
Sent my Gl2 to cannon after having problems with what I thought were the heads, only to be informed today that it is a "electrical board" crash and will cost $1,000 to fix. What shocks me is I have only used this camera on one shoot and it is only two years old. Has anyone had problems with the Gl2? I have no choice but to fix it.
Tim Agnew is offline   Reply With Quote
Old February 26th, 2007, 05:18 PM   #2
Old Boot
How could you have a 2 year old camera and only have used it on 1 shoot?
I've got 2 XM2s and about 400 60miniDV tapes.
I've not heard of a board blow?
Has somebody else owned/used the camera? Are you the first and only owner?
Old February 26th, 2007, 10:38 PM   #3
The only readily fashion to destroy a board is to have it hit by an electrical charge, even static could do it. you could also have the problem if it managed to get wet inside. Usually water inside means buy a new camera.
its a pretty expensive camera to use once ever couple years. Perhaps buy a more economical one.
As in all electronics, once you start having electronics issues they seem to get worse as time passes by.
DATS ALL FOLKS
Dale W. Guthormsen
Old February 26th, 2007, 11:25 PM   #4
interested?
Hey are you interested in buying a new Gl2 instead of getting this one fixed. I have a package I want to get rid off, I don't know if it's legal to post an ebay add but here it is (please don't ban me) :) : http://cgi.ebay.com/ws/eBayISAPI.dll...3267&rd=1&rd=1
Dmitry Yun is offline   Reply With Quote
Old February 27th, 2007, 08:34 AM   #5
Dale:
no, I'm not aware that any of those things happened-I've been very careful with it other than forgetting to clean the heads. I did change tapes from Sony to Panasonic. And I did not mean to imply I've only used the camera "once;" I've used it many times on small projects but just recently on an imortant shoot. I'm not in the business but we do all in-house video for my company. I believe I'm sunk and have to repair it-
I have seen other posts here of the same issue, though. Many circuit board failures. Hmmm?
Old February 27th, 2007, 11:04 AM   #6
i think you have just been unlucky. some damp must of got on the board somehow, or maybee yours was a rogue model, i have not had any problems yet... and dread the day! Your XM is a good camera, dont let the devil get u down!
StMichael
Michael Connor is offline   Reply With Quote
Old February 27th, 2007, 07:17 PM   #7
Now I know: condensation. I live in Fl so the hummidity is intense. Had the Gl2 with me on the west coast in Aug and recall getting the message that there was condensation. Got to be more careful. thanks
Old February 28th, 2007, 07:55 AM   #8
advice i picked up from this site...
Silica gell, pack your camera bag with loads of it. Shoe shops may give u some for free.
Leave bag to acclimitise and get to room temp for couple of hours before opening it.
yr stuffed if u want to film the airport, or getting off plane like!
StMichael
Old March 21st, 2007, 05:25 AM   #9
Tim,
What were the symptoms? I had a "fatal" problem that I posted here last year with my GL-2, but the whole catastrophic failure was only a disconected ribbon to the board. Not to say Cannon is pulling yourleg but I would be interested to know wha the symptoms were!
Bradley D Barber is offline   Reply With Quote
Old March 21st, 2007, 05:58 PM   #10
First, I noticed some blank tapes after recording, along with grey bars over footage. Then, the LCD would not show any footage, just blue screen. I'm fortunate that I got through this past shoot with no problems before it went out. In my case, there was definitely condensation.
