Audio Out of Sync at DVinfo.net
Old March 7th, 2007, 06:07 PM   #1
Audio Out of Sync
So, I was editing some footage last week (Final Cut Pro) and noticed that the audio was out of sync with the video. After a lot of pain, I got it lined up - it was 1sec:2frame out of sync.
This is from a GL1.
This is the first time I've seen the issue happen with any of my cameras (all GL1). I also haven't seen it happen with Premiere. Turned a quick capture/burn into a much longer process.
Why would this happen, how could I prevent it in the future?
Mic - onboard system mic
Lisa Shofner is offline   Reply With Quote
Old March 7th, 2007, 11:35 PM   #2
Old Boot
Are you suggesting it is the GL1. In which case I'd want to run a series iof tests:-
#1 - Monitor straight thru' camera WITHOUT capture to a TV/Monitor.
#2 - Monitor FROM camera capture tape FROM camera to a TV/Monitor.
#3 - Now capture to FILE and monitor that.
#4 - Repeat #1 > #3 with ANOTHER non-GL1 DV camera.
#5 - Repeat #3 with ANOTHER older tape that you know as being correct.
For me this would EITHER nail the camera as the culprit OR remove it from the issue-audit. Once I had reassured myself that the camera was not at fault - this is what you were implying - I'd look to my PC, here an Apple, for any further testing
My money is on it NOT being the camera. This testing would also do something else too. It would suggest that either the Apple capture or supporting program is applying some form of latency OR that within the edit there is latency OR your method of monitoring has introduced some latency. And these you need to test separately.
I know nothing about Apple's or FCP, but you are saying that :"This is the first time I've seen the issue happen with any of my cameras (all GL1). I also haven't seen it happen with Premiere." - Again, this implies that the camera isn;t at fault and that it is your edit deck/monitoring side that has introduced the latency.
Sorry - can't help much further - g
Old March 8th, 2007, 05:32 AM   #3
Was this a consistent 32 frames for the entire cpature? If so, I suspect some stray latency in your capture system.
Or was it a slight drift of the audio from the video over time?
dpalomaki@dspalomaki.com
Old March 8th, 2007, 10:34 AM   #4
Yes, the whole thing was out of sync from the beginging.
I don't know if it is the cam or the machine...but i've loaded video from other cameras, i've loaded video from the same cam. Loaded to Mac, PC, external drive, internal drive. Just the one clip was out of sync.
Not necessarily blaming the camera, but it was my first guess. I mean, the machine has been fine with other cams - and i've done the same thing, same setup, for capturing the footage every time.
I have read a few things about "audio drift" which I am not familiar with, so thought maybe someone else with GL1 experiance would know what could be done if it is a camera setting.
Old March 8th, 2007, 02:18 PM   #5
Location: Central North Carolina (Raleigh, Durham, & surrounding areas)
I've had this happen to me a few times. I don't think my problem was the camera or the capture, but I think it was me. Somewhere in my concentration on the edit, I think I must've moved the slider bar wrong and suddenly I found that my audio was out of sync. Now, I lock down every track that I'm not directly working on and save my project every time I get something just the way I want it. At roughly half-way complete, I create a new file name and save it to another hard drive. I thought I'd done all this on a current Christmas project, only to find my that audio was 67 frames ahead of one of the video tracks. Oh, well, it only took 4 hours to fix. I guess it coulda been worse!
Mark
Mark Holland is offline   Reply With Quote
Old March 10th, 2007, 06:44 AM   #6
The audio drift thing, when it happens, is a gradual effect that occurs over the length of a long clip. At there start of th capture they are in sync an at the end they are slightly out of synch. This is caused by a very slight difference between the audio and video clocks. You might see in someof the end the end clips if it if you capture a 30 minute clip and then cut it into many short clips But that does not sound like what you describe. Some NLE's will compensate for this by settings.
As Mark notes, it is possible to get the audio and video out of sync once they are on a timeline of they are unlinked/unlocked.
Don Palomaki is offline   Reply
