GL2 manual settings
Hi, I have my GL2 set to manual, and when i am shooting a scene and i have to turn off the camera to explain something to the actors, I turn it back on and my settings are gone and it takes time to re adjust everything....Is ther anyway I can like store my settings or something like a preset...Also, can this be done with white balance?
Also. has anyone seen the movie amelie? Well, I am trying to figure out how to color correct my footage to give it a green color without killing my image. Does Anyone know how to color correct without making everything green? Last edited by Tatsuya Graham; April 8th, 2007 at 01:01 PM. Reason: amelie color correcting |
Backup Battery?
When you say all the setting are gone, do you mean the time setting, too? If so, your backup battery may need replacing. On a GL2, you can replace it yourself. It is like a watch battery. The manual gives the specs. I bought one at Walmart. Actually it was one of the few carried by Walmart.
Mike Donley |
well, its something like that, but if i were to set like the gain to 0 and turn off the camera, it will jump up to 12db when i turn it back on. Is that still the battery?
If you use the power switch to turn it OFF/ON, all setting will drop to their default setting when you turn the camcorder back on..
However, if you power down using the Standby/Lock switch, most manual settings will be retained when you restart by moving the switch from Lock to Standby. BTW: A bad or missing backup battery should give a viewfinder indication. Does this solve your problem.
dpalomaki@dspalomaki.com |
#5 |
Yes, thank you, I didnt know that the standby would do that for me...That is really going to help me out....Thanx Don.
~Tatsuya Graham |
