AT897 or RODE NTG-2 or other mic for HV20 - Page 2 at DVinfo.net
Old November 10th, 2007, 08:27 PM   #16
I went with the Canon mic, the DM-50, I think it is. Check the owner's guide. It is a noticeable improvement over the built in mic. You can hear the difference when monitoring with headphones. You can find them cheaper than the Rode.
What pushed me in favor of the Canon mic was two things:
1) runs from the accessory shoe. No external power needed
2) Small form factor.
No offense to anyone who answered already, but I couldn't see the ergonomics of mounting a big shotgun onto a tiny camera. Same with the Beechtek XLR adapter. I like the HV20 because it's almost inconspicuous, like a Leica still camera. Mounting a big mic and adapter negates that. I might as well carry around a bigger rig.
Some one here once posted a comparison of the Canon and Rode mics. Do a search....I think they were comparable in terms of sound.
Cheers
Bob
Bob Kerner is offline   Reply With Quote
Old November 12th, 2007, 12:04 PM   #17
A big shotgun & wide-angle adapter definitely raises the profile of the HV20, and upsets its ergonomics a bit. But the improvement in sound is worth it. You are still saving a significant amount of size & weight over a bigger camera (ie. an XHA1).
Although I use an AT897, I may also pick up a Rode or a DM-50 for a lower profile mic option.
Bored? Check out my blog (shot with Sony EX1, Panasonic TM700, Nikon D7100, Sony NEX-5N, GoPro2): LongLongHoneymoon.com
C.S. Michael is offline   Reply With Quote
Old November 12th, 2007, 03:23 PM   #18
Here's an Audio Technica mic that is short, 7 inches, made for video camera use:
http://www.bhphotovideo.com/c/produc...r_Shotgun.html
The AT897 is 11 inches long.
Here is a matching adapter:
http://www.bhphotovideo.com/c/produc...w_to_High.html
Here is a shockmount:
http://www.bhphotovideo.com/c/produc...hockmount.html
For stereo, the Rode VideoMic is a good choice:
http://www.bhphotovideo.com/c/produc...ic_Camera.html
The Rode VideoMic also comes in mono:
http://www.bhphotovideo.com/c/produc...a_Mounted.html
For the HV20 I think the best choices are the Rode VideoMic (built-in shock mount, size, quality sound) or the Canon DM50 (with sound indistinguishable from the Rode VideoMic, but with less of a shockmount). Both (in mono) cost $150:
http://www.bhphotovideo.com/c/produc...icrophone.html
Old November 13th, 2007, 04:54 AM   #19
I want to play around with recording a band with my HV20, and after reading everyone, I'm thinking the Rode videomic...am I correct in thinking the stereo version for music? Later I think I will add a recorder once I get comfortable and get some more $$ to play with. So...stereo or mono? Tks folks. bob
Bob Hollifield is offline   Reply With Quote
Old November 13th, 2007, 01:37 PM   #20
I would go with the Rode StereoVideoMic for music. While I don't do music I've had excellent luck with mine mounted on a stand with boom and suspended close to the talent (with a 16' stereo extension cord).
For mounting on the camera I use this bracket meant for mounting a flash centered over something like a Hasselblad.
http://www.veachco.com/j120mhBW.jpg
While the grip is meant for the left hand I mount the camcorder the other way and grip with my right so the fold out LCD isn't blocked. If you don't use something like this that gets the mic up high, the Deadcat windmuff (which I wouldn't be without outdoors") lets "fur" hang down into the field of view.
Hope this helps.
Old November 13th, 2007, 03:55 PM   #21
Thanks Bruce for the info. I've got a flash mount I use with my Nikon 35mm stuff, so that would work pretty good. bob
Old November 13th, 2007, 04:07 PM   #22
Originally Posted by Bruce Foreman View Post
I would go with the Rode StereoVideoMic for music. While I don't do music I've had excellent luck with mine mounted on a stand with boom and suspended close to the talent (with a 16' stereo extension cord)..
Bruce, do you experience any background noise due to unbalanced connection? (long stereo extention cord). I have an inexpensive audio-technica stereo microphone and it works OK if I connect it on my camera, but when I connect it using a long stereo extention cord, then the camera picks background humming noise.
Thanks.
P.
Pedanes Bol is offline   Reply With Quote
Old November 14th, 2007, 10:28 AM   #23
Me64
Check out the new post 'ME64 and Sony wide angle combo'.....should have postedd it here too...
Ben Hillier is offline   Reply With Quote
Old November 14th, 2007, 05:43 PM   #24
Thanks for all the comments.
I ended up checking out online reviews.
Here's one that lets you listen to recordings made with various mics.
http://www.dvcreators.net/shotgun-shootout/
I also asked both online and local video store which mics they recommend.
bhphotovideo.com and ebay.com others offer plenty of choices also.
Brandon S. shared his set up with the AT and bracket mount which looked like the way to go.
I went with the RODE NTG-2 with xlr/mini adaptor plus bracket with Rode mount from bhphotovideo.com.
After a couple outdoor and indoor tests, I am happy with the improved sound. There is a big improvement in sound quality. For indoor, I will use lav mics though when able.
Jimmy Finn is offline   Reply
