Downloading still images at DVinfo.net
Old January 19th, 2008, 01:53 PM   #1
The HV20 Manual states: Users of Mac OS X: Your camcorder is equipped with the standard Picture Transfer Protocol allowing you to download still images simply by connecting the camcorder to a computer using the USB cable without installing the software from the supplied software CD-ROM.
I have made this connection and the display shows "PC CONNECT", but I see no icon on my desktop for the camcorder nor does pushing any buttons on the camcorder seem to do anything.
What am I missing?
Tony
Tony Markle is offline   Reply With Quote
Old January 19th, 2008, 11:02 PM   #2
Did you switch the camera mode to SD card mode (same mode for just taking pictures)? It won't transfer pictures with iPhoto unless you do. Also, you might have to run iPhoto if you have disabled it to run automatically when a still camera is hooked up.
Kelly OHara is offline   Reply With Quote
Old January 20th, 2008, 02:40 AM   #3
You can also use GraphicConverter to import stills or the utility "Image Capture.app". Or just drag them in the Finder when you see the card icon.
Depending on what you are doing, iPhoto can try to be too helpful.
Old January 21st, 2008, 04:13 PM   #4
Image Capture takes 1/2 hour for 1 gig.- anything better?
Image capture is free software that comes with the OSX.
Make sure your camera is on playback mode, set to the stills, and connect the USB cable to camera & computer. Launch Image Capture. Set the parameters (download photo, post actions). Run it.
It seems to take FOREVER on my iMac G5. It's all USB-1 speed, not zippy USB-2. Come to think of it, anyone have any ways to improve on that? It takes a half hour to download a gig, which is pathetic.
Best, Anthony
Anthony Torres is offline   Reply With Quote
Old January 21st, 2008, 04:36 PM   #5
Just buy a Mini SD card reader... much more convenient than downloading from the camcorder.
Old January 21st, 2008, 08:13 PM   #6
Thanks for all the replies, but my original question stated that NONE of the software any of you mentioned should be required, according to the manual.
"Users of Mac OS X: Your camcorder is equipped with the standard Picture Transfer Protocol allowing you to download still images simply by connecting the camcorder to a computer using the USB cable without installing the software from the supplied software CD-ROM."
Tony
Old January 21st, 2008, 09:11 PM   #7
Tony-
Picture Transfer Protocol does not make the flash drives mount as a viewable drive. To use Picture Transfer Protocol, you'll need to use iPhoto or Image Capture to download the pictures via USB to your Mac.
Leonard Wong is offline   Reply With Quote
Old January 22nd, 2008, 12:27 AM   #8
Another point of contention, since we're going there.... Canon says you don't need any of the software from their CD. That does not mean you do not need something.
On the mac, you already should have iPhoto. Colin suggested using Image Capture or Graphic Converter. Macs already have Image Capture and some come with Graphic Converter. If you have Aperture, you may use that too. Or even use Chris Hurd's suggestion of just copying the files using a card reader, that will work just fine too.
Canon's implication is that you can use the same method to retrieve the images that you would for any digital still camera, and on the Mac, that is using iPhoto or Image Capture to get the pictures.
The mac can automate the process with a little bit of setup, but if you've disabled it, it won't work at all. Run Image Capture, open its preferences and see what "When a camera is connected, open: " is set to. If it's set to "No Application", then nothing will run when you connect your HV20 in SD card mode. Set it to an application and then you will have something happen as you seem to be expecting.
