Zoom presets with HV-30? at DVinfo.net
Old December 13th, 2008, 03:04 PM   #1
Hello Forum members,
Has anybody been able to preset the zoom sweep setting? I am filming with two side-by-side HV-30 cams. The zoom on each cam is all or nothing, in the stock default. I wondered if the zoom could be stepped in increments up to full in, with some code options? full zoom is too close, full out is too far, and without presets, there is now way to sync both cams on the same setting. Thanks for any help.
Cheers,
Christo
Christo Aaron is offline   Reply With Quote
Old December 13th, 2008, 07:23 PM   #2
Go Cycle
Press the FUNCTION BUTTON
SCROLL to the bottom icon=MENU
PRESS the SCROLL button.
It will now open to Camera System
CHOOSE ZOOM SPEED via > >> >>> icon
Cheers,
Christo
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old December 13th, 2008, 11:08 PM   #3
Zoom Preset STOPS?
Hello Lou,
Before I go there, will your suggestion provide me with PRESET STOPS, rather than ZOOM SPEEDS. Such as 0X/ 2X /4X /Max or can this only provide faster or slower ZOOM SPEEDS?
Christo
Old December 14th, 2008, 02:57 AM   #4
There might be a way of doing this with the remote - one remote controlling both cameras.
At least you should be able to get them both to do the same thing, with a bit of luck, if they are side by side.
(I've had it happen by accident with two cameras the same, even when they were some distance from each other).
Last edited by Colin McDonald; December 14th, 2008 at 03:10 AM. Reason: Clarification
Old December 14th, 2008, 06:35 PM   #5
Preset Stops for Zoom?
Thanks Colin,
Let me ask you this, did you find that this particular time (it happened) both cams had stopped at a synced zoom increment? Or, were both cams in sync each time you toggled the zoom in or out? That would be a simple solution, and I will give that a real test trial. Unfortunately, there will be no real way of knowing if both were exactly in sync until I render into a final cut anaglyph file. What I was hoping for, was some type of firmware screen readout % #of zoom, maybe I missed an adjustment the owners manual which would give me a number readout on the zoom screen line. As it is, I cannot get both cams in manual sync between full zoom or no zoom. This is not functional, when trying to shoot a midrange shot in stereo.
Cheers,
Christo
Old December 15th, 2008, 12:50 AM   #6
Both cameras zoomed in and out in sync but from different staring points. I was using small adjustments at first but eventually both cameras went to full wide on a sustained push of the W toggle.
If you start from full wide or full zoom and carefully aim the remote I would expect two HV-30s to remain in sync, but you won't know for sure until you try.
Old December 15th, 2008, 07:36 AM   #7
Sync of Stereo HV-30 Cams
Thanks Again Colin,
I'll demo test all these suggestions tonight. Maybe also, if the one remote triggers both cams in the zooming stops, then each cam may also be used to start record in sync, with one remote as well?
Manual starts, or zooms, create shaky motion, of beginning filmed clips. Usually this is edited out prior to the audio edit sync click. I like to think, remote control use may solve some of these variables. I do like the compact HV-30 duel stereo cams, working on city streets. As I don't like to draw attention to my equipment, for someone to heist me.
Cheers,
Christo
