Anyone Using a Vixia HF series for Professional work? - Page 4 at DVinfo.net
Old October 27th, 2010, 01:29 PM   #46
Thank you for pointing that out. I did not realize the Vixia's had explicit shutter speeds. They do not display when manually adjusting the exposure in [P]. I'll have to change my approach (use TV Shutterprio.ae?).
Christian Brown is offline   Reply With Quote
Old December 4th, 2010, 05:19 PM   #47
The only time I can view shutter speeds is on playback of the video , when put on display mode.
Roy Beazley is offline   Reply With Quote
Old December 4th, 2010, 06:30 PM   #48
Personally I never use any mode except Tv so that I can hold shutter speed constant (usually at 1/60 for 30P or 60i; 1/48 for 24P .... doing this requires the use of an ND filter in bright conditions). Shutter speed remains visible at all times in Tv mode.
Old December 4th, 2010, 10:33 PM   #49
can you set the shutter speed on its on?
Old December 4th, 2010, 10:44 PM   #50
Yes, in Tv mode you set the shutter, and the iris still varies automatically (unless you also choose to lock exposure, in which case both shutter and iris remain fixed).
Old December 7th, 2010, 03:59 PM   #51
Graham what camera are you using? I don't see a Tv mode on my HR-10....
Old December 7th, 2010, 10:21 PM   #52
Vixia HF10
Old December 10th, 2010, 08:12 PM   #53
Ahhhh there's the difference....thanks Graham....$800.....out of my range right now...maybe soon...
Tony B.
