Dubbing Music at DVinfo.net
Old October 30th, 2006, 09:00 PM   #1
Dubbing Music
I have used Stereo ! for all my recordings with the HV-10.
I've noticed that on playback you have several choices depending on what you want to do ie...Stereo 1, Stereo 2, Mix 1-1 and Mix/Variable.
Which do you think is best for adding Music, and should I record in the same setting that I will use for playback. I'm using iMovie HD.
Thanks, Your input will be appreciated.
Luis A. Diaz is offline   Reply With Quote
Old October 30th, 2006, 09:06 PM   #2
For the most flexibility dub the music over your video in post.
If you do it in camera I believe 'Mix/Variable' will allow you to balance the music against the recorded sound.
Lee Wilson is offline   Reply
