HV10 v HV20 questions at DVinfo.net
Old April 3rd, 2007, 12:29 PM   #1
I had trouble checking the specs for the HV20, but I believe it's lens is .43 to the HV10's .37. Right?
And are the batteries for both the same or different?
Though using the same CMOS chip and processor I've the HV20 is noiser. Anything to the contrary?
thanks,
elmer
Elmer Lang is offline   Reply With Quote
Old April 3rd, 2007, 12:42 PM   #2
I meant to ask: Though using the same CMOS chip and processor, another review seemed to imply the HV20 is noiser. Not true?
Old April 3rd, 2007, 01:02 PM   #3
Hi Elmer,
First off the lens of the HV20 is bigger than the HV10. Second, unfortunately the HV20 uses the same batteries, but fortunately for me it does use the same batteries as my Canon S80 digital still cam.
Lastly, in typical lighting there is no increase in noise. In very dim lighting there is a slight increase in noise but a brighter, much more usable picture (as stated by CCI) without those vertical lines that show up on the HV10 in dim light. You'll definitely prefer the low light shooting of the HV20 vs the HV10.
Bottom line is I find the HV20 to be a definite step up from the HV10. The greatly enhanced ergonomics is also a plus.
Ken Ross is offline   Reply With Quote
Old April 3rd, 2007, 01:22 PM   #4
Hi Ken,
Thanks much for the info.
But maybe because I've been making errors myself, I was wondering did you actually mean the HV20 uses different batteries? Somehow your quote above created uncertainty in my meager brain.
Sorry, if the obvious isn't obvious, but thanks for your info.
best,
elmer
Old April 4th, 2007, 07:41 AM   #5
Elmer, that's because as I read my post I see I was totally incoherent. Yes, the HV20 uses different batteries. What I meant was it uses the same batteries as my Canon S80 digital camera. Sorry for the confusion.
Old April 4th, 2007, 07:57 AM   #6
thanks,
elmer
Check Chris's post here:
http://www.hdvinfo.net/articles/cano...rehv10hv20.php
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply
