What is the HDMI output? at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old December 18th, 2011, 11:18 PM   #1
Anybody know what the signal coming out of the XA10 HDMI is? e.g. (4:2:2, 10bit, or 8bit)?
Mark Goodsell
Mark Goodsell is offline   Reply With Quote
Old December 20th, 2011, 08:00 PM   #2
Re: What is the HDMI output?
HDMI out on the XA10 is likely to be 8 bit.
Michael Kraus is offline   Reply With Quote
Old December 23rd, 2011, 03:20 PM   #3
FWIW: I've heard that the typical human eye can resolve steps in a 6 to 7 bit gray scale, but cannot in in an 8-bit scale. However, image processing artifacts may easily reduce an 8-bit original to something less, even if the final output is nominally 8-bit.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
