LANC Controller compatibility at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old May 20th, 2014, 11:43 PM   #1
Will the Sony RM1BP Lanc Controller work on the Canon VIXIA HF G20 (which has a Lanc input)
Vince Pachiano is offline   Reply With Quote
Old May 22nd, 2014, 05:52 AM   #2
Re: LANC Controller compatibility
Probably (I have not used it), but it is possible that all available functions on the controller might not be implemented in the camcorder - in which case only some would work.
The Canon ZR-2000 was listed as a G20 accessory, but apparently has been discontinued by Canon. And Canon ZR-1000s can still be found as well. They should work fully with the G30 (the ZR-1000 works with my XA20).
LANC is a sony-defined protocol and contains many defined commands that may or may not be implemented in a specific system. It was mainly used on Sony and Canon,camcorders and VCRs) There are a number of third party LANC controllers offered as well.
dpalomaki@dspalomaki.com
Old May 22nd, 2014, 08:49 AM   #3
Don's right, as usual -- looking over the product page for that controller at Sony Product Detail Page RM1BP -- there's no reason I can see why it shouldn't work just fine with a Canon VIXIA camcorder.
Old May 22nd, 2014, 07:58 PM   #4
Yep, it definitely worked.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
