XA-25 WiFi remote and manual settings at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old March 31st, 2015, 03:13 AM   #1
Hi
When recording live performances (theatre, concerts) I often use my XA-25 in unattended mode, with a laptop and the WiFi Remote app to control things during recording.
The problem is that, once the recording is started, it is impossible to change settings like iris & gain if the camcorder is in M (manual) shooting mode.
When shooting in the other modes (P, Av, Tv), it is possible to adjust the exposure compensation, but only within a range that is determined by the exposure at the time the recording is started...which can be a problem if e.g. recording is started in the dark just before the curtain opening...
I do have firmware 1.0.4.0, which is the most current one AFAIK.
Any suggestion or workaround ?
Benoit Matthys is offline   Reply With Quote
Old March 31st, 2015, 12:43 PM   #2
Re: XA-25 WiFi remote and manual settings
Hi,
I also have an XA25.
So far only once i had my XA25 controlled with WIFI.
But what Remote App do you mean?
I controlled my XA25 with an normal Browser, the IP-Adress, and no App.
Andreas
Andreas Jaeger is offline   Reply With Quote
Old April 1st, 2015, 01:58 AM   #3
Yes, I mean remotely with a normal web browser (and the Remote Wi-Fi "app" built into the camcorder)
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
