If I have the wrong conversion lens setting on, does it impact focus? at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old February 23rd, 2022, 08:19 PM   #1
I'm curious. Sometimes i use my wide lens with my Canon XA10 and sometimes I don't. If I have it off, but have the conversion lens setting set to wide (or vice versa), will that impact my ability to get a sharp focus?
Noam Osband is offline   Reply With Quote
Old February 24th, 2022, 06:52 AM   #2
Re: If I have the wrong conversion lens setting on, does it impact focus?
Per the note on page 148 of the manual it may effect speed of autofocus, distance marking on the screen, image stabilization effectiveness, and minimum object distance. Subject to that I would not expect it to effect ability to ultimately achieve accurate focus within the capability of the lenses and adapters in use.
Try run some test on your gear to verify any effects.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
