Missing Canon XF Utility ? here is my trick at DVinfo.net
Old August 3rd, 2011, 09:45 PM   #1
Hello,
For those of you like me who have lost their CD containing XF Utility, i wanted to share my method to transfert all the clips from the CF card to a single directory on hard disk.
open a command line window and type the following:
FOR /R h:\contents %a IN (*.mxf) do copy %a "f:\target_directory" /Y
where h:\ is the CF card and f:\ the external HDD.
you can then import all the directory containing your clips onto your NLE.
Hope this help !
Cedric Pottier is offline   Reply With Quote
Old August 3rd, 2011, 10:11 PM   #2
Old Boot
Re: Missing Canon XF Utility ? here is my trick
Good ole DOS!
I still have my DOS primer. I almost understand your parameters.
Thanks for the "script". Is it called that? Or just a "command"?
Grazie
Old August 3rd, 2011, 10:23 PM   #3
this is more simple than a script, i use it since one year now.
just a DOS command line.
it will copy all your MXF clips automatically to a single directory.
On windows, under "execute", type "cmd" to open the command line window.
Old August 4th, 2011, 01:21 AM   #4
just another second trick:
Under Win-7 u can use the find-box right side on the top of the navigation-bar
there you just type in "mxf"
it will list all found mxf-files, it also list this files sortet
now you can simple copy them into a new folder.
Markus Oginero is offline   Reply With Quote
Old August 4th, 2011, 01:56 AM   #5
Old Boot
Under Win-7 u can use the find-box right side on the top of the navigation-bar there you just type in "mxf"
I'm just adoring Win7, JUST for that facility. It's completely knocked the spots off of XP.
Is there any "other" info omitted/lost in that approach? Sounds straightforward.
Grazie
Graham Bernard is offline   Reply
