Sharpness settings on XF305? at DVinfo.net
Old August 14th, 2011, 01:36 PM   #1
I shoot landscapes with lots of fine detail (leaves, grass, trees) and have found that the footage out of my 305 is a little soft. So I increased the Sharpness Level in a Custom Picture File from the default zero to +10, and also the H Detail Freqency from zero to +4.
This has improved horizontal sharpness without generating any annoying halos.
But much of the details in my shots are vertical, such as grasses, trees, etc.
I don't find a setting for vertical detail sharpness, and am wondering if someone can help me improve vertical sharpness? I see that there is an HV Detail Balance, which adjusts the ratio between horizontal and vertical detail, but no setting that specifically addresses vertical detail.
Also, I am wondering if reducing Coring will also help apply sharpness to fine details?
What about using Select--is raising this variable a better way to increase sharpness for fine detail?
Appreciate hearing from those who have had experience making these changes.
Thanks.
Bob Prichard is offline   Reply
