Flickering images at DVinfo.net
Old January 22nd, 2012, 06:02 AM   #1
Flickering images
Hi,
I own the xf300 since a couple of days now. And when i'm filming there is flickering "banding" visible. (See sample)
I tried playing with the hertz setting. Arround 50 since i'm living in a PAL area, but also 60 and some lower values. However it doesnt seem to help. I also tried filming with different CP files, flicker reduction turned on and off but nothing removes these bandings.
I hope you guys have some tips.
Check the file overhere. Its raw straight from the camera
hotfile.com/dl/142955493/f89c4e6/AA020601.MXF.html
Edsard Keuning is offline   Reply With Quote
Old January 27th, 2012, 09:31 AM   #2
Re: Flickering images
Hi - can you post something on Vimeo as that would be easier to view rather than expecting us to download stuff.
Cheers,
Chris
Chris D
www.chrisd.tv
Chris Dickinson is offline   Reply With Quote
Old February 3rd, 2012, 04:26 PM   #3
I uploaded it to a download site because vimeo compresses the material. This way i can show the raw footage
Old February 3rd, 2012, 04:31 PM   #4
Here is a Vimeo link. Hope somebody knows the answer.
Old February 3rd, 2012, 05:23 PM   #5
Images: 18
Hi, Edsard............
Did you have both the shutter speed and the aperture fixed for this shot? White balance?
What's interesting (on my screen at least) is that most of the flickering seems to be perfectly in time with the strobes firing on both right and left of the performers.
Not having the camera, anyone know of anything else that can simply go "walk about" unless it's told not to?
OR, given the speed with which the lighting was changeing, is this a symptom of the dreaded CMOS "flash" problem? (there, just to show my ignorance - is it a CMOS sensor?).
Best I can do for now.
CS
Old February 3rd, 2012, 05:39 PM   #6
So does this happen under normal lighting? or just under rapid stage strobes?
Matt Ford is offline   Reply With Quote
Old February 4th, 2012, 04:27 AM   #7
Everything was fixed, nothing was set on Auto.
As far as i know the strobe wasn't used in this shot. Everything that you see flickering are moving lights. (The strobe overthere is so strong that you can't miss it)
I have a feeling it is being caused by the refresh rate of LED lights and thats why i tried different Hertz settings.
I also have an XH-A1 and that camera didn't had the problem so i guess its the CMOS sensor that causes this problem.
@matt
I've also seen it flickering in my room but i didn't record that
Old February 4th, 2012, 08:39 AM   #8
Ok. I shot for 6 weeks in the US on a PAL 305 last summer. The 2 occasions I had problems were firstly industrial lighting, and tweaking syncro solved that one. The other issue which I think you are having is flicker reduction banding during under exposure. The EX3's would do this also. I was shooting a guitar player and when I went in close to his hands on his very black guitar I got this distinctive banding, as I was shooting PAL and moving locations at speed I had FR on. A quick google took me to a Sony forum and the solution. These sensors really need good exposure especially if shooting with high gain and keep FR off. Do some tests and let us know but nail the exposure!
PS the lights that are flickering in your shot are so fast that is what we mean by strobing, they are not the long burn pulse of old they are high speed short duration, and there are several which will give a strobe affect.
Old February 4th, 2012, 09:26 AM   #9
I also noticed it happens more when I'm zoomed in. The demo shot was also shot zoomed in at like 70%.
I'm gonna do some more tests in the next weeks. But if i understand you correct there is nothing to do about this problem if you don't have enough light. I only shot at 3dB gain. I'm gonna try if it makes any difference when I'm shooting at 0 or -3dB.
When i find out more I'll make another post. It could take a while since I'm not at these locations every day ;-)
Old February 4th, 2012, 04:01 PM   #10
Dont be afraid of gain up to 12 db in this kind of situation, exposed correctly the noise/grain is ok, atmospheric even. Exposure is the key!
Old February 4th, 2012, 09:26 PM   #11
I'm allergic for noise ;-), but I'll make some test shots with different gain settings.
Thanks for the info!
Old February 14th, 2012, 09:50 AM   #12
Yup, looks to me that its a problem with frequency of the flashing light v's the CMOS. I really don't know what the point of flicker reduction is bcs whenever I've tried it, it's caused flicker..! So keep that off...
One idea may be to shoot at a slower shutter speed of 1/25th... might help to smooth things out a bit...
You may also have to experience with camera angles, fields of view etc, to find the best compromise.
Some problems we can't solve, we can only minimise.
Cheers,
Chris
Chris D
www.chrisd.tv
Old February 21st, 2012, 10:40 AM   #13
It COULD stand in relation of LED Light (likes to flicker at 60Hz) vs. 50Hz recording CMOS.
Always when I film stages I ask the light engineer to go thru all light scenes while Light/Soundcheck.
Use a small 9" (or bigger ) monitor to review, small lcd screens also tend to calm down flickering problems.
br
ULi
Uli Mors is offline   Reply
