Could this technique be used to sync the timecode of XF100's? at DVinfo.net
Old February 2nd, 2012, 12:44 PM   #1
XL2 Free Run Time Code as an External Sync by Chris Hurd
The basics:
1. Put two or more cameras in time code in Free Run mode.
2. Use single remote control to reset all the cameras at once.
David Trayers is offline   Reply With Quote
Old February 6th, 2012, 06:51 PM   #2
Re: Could this technique be used to sync the timecode of XF100's?
Could this work?????
Regards
Mike
Mike Ayotte is offline   Reply With Quote
Old May 25th, 2012, 02:03 PM   #3
I wanted to give an update on this technique.. and it indeed does work, and except for a minor issue works well.
I had the opportunity to shoot with two XF100's (actually, and XF100 and XF105) last weekend. I had rented the 105 and I copied all the settings on the 100 to the SD card then imported them into the 105. Both I put in Free Run timecode, and I manually set the menus to the 'reset' position. I put the cameras next to each other and with the remote reset the timecode on both at the same moment.
When I imported the clips into Premiere Pro CS6 and synchronized the clips, it synced them perfectly by the timecode. I used a clapper for redundancy, but it wasn't needed.
The only issue is that the cameras drifted over time. After 15 hours (overnight), they were ~0.25 seconds off. I took a photo of their LCD's next to each other to see the difference. So I for the three shows I did, I just reset the timecodes right before the start.
Old August 28th, 2012, 08:18 PM   #4
That was precisely what had to be done with the XL2 in teams. Takes but a second and they're synced again.
If you're not part of the solution, you're part of the precipitate.
A.D.Wyatt Norton is offline   Reply With Quote
Old August 29th, 2012, 08:32 AM   #5
Thanks for sharing the result. I was interested to know if this worked. Interesting to know the relative drift on your camera too. I also often do long continuous recordings of performances.
Brett
Brett Delmage is offline   Reply
