Glidecam 2000 Pro + A1?
Hello,
I have a Canon XH A1 and a Glidecam 2000 Pro, i've spent probably close to an hour with both of these and I simply can't get it down right. I only have the camera + 970 (i believe) battery, nothing else, it's definitely under 6 pounds. Could anyone tell me their setup? Or suggestions for balancing the a1 specifically? |
I got the same specs as you and got it working just fine. Try using 4 weights on each side and make sure their round edges of the weights touch the 3 ends of the metal plate. (I dunno how to explain it, but make sure the sides of the metal plate supporting the weights form a tangent to the weights. Adjust the height to make it as high as you can and now you are ready to balance the camera axis by loosing the screws in the top plate and moving it slightly to the sidesm, front and back. Check again the Glidecam manual for more instructions. It is really heavy the first time
Thanks again, could you tell me your hole position? I'm going to start trying with that many weights now. EDIT: Alright tried that, got it perfectly balanced but when i move it around, it swings back and forth, so the length isnt right i guess. Ill continue to experiment. |
Also... you are going to need some practice before getting the best out of your glidecam. You need to learn how to keep it steady with your left hand and applying the least force with it at the same time. You must carry all the weight with your right hand and it will not be easy in the beginning. Try also beding your knees a little when walking so you dont get any kind of bouncing when walking. Practice a lot. thats the key
Edit: Still can't balance, could you specify the rest of what you use? |
What is your drop time (length of time it takes to fall from an initial horizontal position to the vertical position)?
Hi Carlos,
Please can you post an image of your setup, I have the same problem as well. Thanks~ Quote:
This thread may help out a bit:
http://dvinfo.net/conf/showthread.php?t=86940 I used it to balance my GC2000 & A1. |
I have the same setup as well. If you all are still having trouble I will make a small video to explain the setup. It was a lot easier with the vx2100. however it can be done with the a1 as well.
After using the link I posted above here are my results from my first tries with the Glidecam 2000 and Canon XH-A1
http://www.simplethoughtproductions....m-canon-xh-a1/ |
| All times are GMT -6. The time now is 06:17 PM. |
