Mini DV tape - dumb question at DVinfo.net
Old October 8th, 2007, 08:51 AM   #1
Two questions actually:
(1) I have a number of Sony SD Mini DV tapes. Can these be used in the A-1 or must I use some sort of high def Mini DV tape?
(2) I have been using a GL2 that is going back. Can I play back footage I shot on the GL2 through the A-1?
If not, is there some way to playback the footage shot on the GL2(SD mini DV tape) for editing purposes down the road...when I no longer have the GL2?
Tx.
Rog Lee
Roger Lee is offline   Reply With Quote
Old October 8th, 2007, 09:11 AM   #2
http://www.dvinfo.net/conf/showthread.php?t=101973
M
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old October 8th, 2007, 09:16 AM   #3
You can play back your GL2 footage without any problems on A1. It's a normal DV SD footage which is fully supported by A1.
Mateusz Metelski is offline   Reply With Quote
Old October 8th, 2007, 11:43 AM   #4
Thanks for the help. I did a search but must have used the wrong search criteria as I could not find out much info.
Thanks again.
Rog Lee
