Don't slam the Pelican case. at DVinfo.net
Old January 10th, 2008, 04:43 AM   #1
A thought struck me as I was finishing cutting up the foam for the A1 to fit the Pelican 1510 case. DON'T slam/close those case lids real fast, the air pressure will likely knock out the capsule in the cameras mic, and any other mics in there.
Cheers.
Old January 10th, 2008, 08:08 AM   #2
A better warning might be... Don't run with scissors.
Old January 10th, 2008, 08:42 AM   #3
A little of topic but since my pelican case will be in today, what do you carve the foam with?
2 Canon XF305's
Kyser Photography www.kyserphoto.com
Denny Kyser is offline   Reply With Quote
Old January 10th, 2008, 08:55 AM   #4
Images: 10
Stick the foam in your freezer for a few hours before cutting. It makes the job much easier.
Old January 10th, 2008, 09:43 AM   #5
If you're not using 'pick and pluck' foam then cut foam with an electric carving knife. A trick I learned back in my theatre days from the seventies.
Richard Alvarez is offline   Reply With Quote
Old January 10th, 2008, 11:06 AM   #6
It as others have suggested a knife or what ever for regular foam but in the case of pelican the foam is precut into tiny squares that are just barely attached. You just push your fingers in and pull out the squares.
Josh Chesarek is offline   Reply With Quote
Old January 10th, 2008, 01:24 PM   #7
If you're using the 'pick and pluck foam', do it with a steel ruler.
Bill Watson is offline   Reply With Quote
Old January 10th, 2008, 03:03 PM   #8
I did it by positioning the A1 in place over by the hinges so with the 1510 standing upright the weight is at the bottom. I marked the pnp foam with a Sharpie then used a new Stanley 18mm blade in a sawing fashion. Took me 2 hours and I haven't done the battery or filters yet.
Much positioning checks with thankfully little error and no blood this time.
Cheers.
Old January 10th, 2008, 03:47 PM   #9
Originally Posted by Allan Black View Post
I did it by positioning the A1 in place over by the hinges so with the 1510 standing upright the weight is at the bottom. I marked the foam with a Sharpie then used a new Stanley 18mm blade in a sawing fashion. Took me 2 hours and I haven't done the battery or filters yet.
Cheers.
2 HOURS........I thought Aussies were faster than that!
Jim Martin is offline   Reply With Quote
Old January 10th, 2008, 03:49 PM   #10
I swear by pelican cases. I've stood on top of one to get a shot. I've never heard of the air issue. That's something I would send Pelican an email about, they might already know, but it may cause them to scratch their head a little.
Old January 10th, 2008, 04:01 PM   #11
I left out...and some beers. :)
Old January 10th, 2008, 05:00 PM   #12
I thought that's what the pressure valve on the Pelican was for? To avoid air pressure inside? Or is that just for altitude pressure?
Kellen Dengler is offline   Reply With Quote
Old January 10th, 2008, 07:27 PM   #13
That would explain the blood-letting thing.....
Old December 19th, 2020, 04:45 PM   #14
Re: Don't slam the Pelican case.
Hah! right Jim. It’s probably not too late to ask Santa for a good protective case for your new gear. When I bought mine 12 years ago, Pelican was the only game in town, but since then a couple of other brands have surfaced.
Disclaimer, the prices listed are 1 year old so don’t take any notice of them and after I saw a bright orange Pelican attract unwanted attention at a crowded air show, just buy a black one ...
Happy Xmas.
Cheers.
Old December 19th, 2020, 04:49 PM   #15
Nice review!!
Steven Davis is offline   Reply
