Firestore and NTG-2 with Rode Shock Mount at DVinfo.net
Old February 18th, 2008, 02:04 PM   #1
Hi All,
My Firestore is occupying the hot shoe on my A1, so I can't put the NTG-2 there.
I don't see another way to mount it unless I use the mic clamp that came with the camera, which defeats the purpose of buying the shock mount.
Can anybody suggest something that would allow me to use the Shock Mount?
Reggie Giles
Reggie Giles is offline   Reply With Quote
Old February 18th, 2008, 02:07 PM   #2
Use the Rode SM5 shockmount in the mic clamp instead.
http://www.videogear.co.uk/index.php...d&productId=26
Simon Sumner is offline   Reply With Quote
Old February 18th, 2008, 02:13 PM   #3
Thanks, Simon.
A big duhh on my part.
Old February 18th, 2008, 03:14 PM   #4
Or there is this:
http://www.thej-rod.com/
Kellen Dengler is offline   Reply With Quote
Old February 21st, 2008, 05:48 AM   #5
Originally Posted by Kellen Dengler View Post
Or there is this:
Thanks for the recommendation Kellen !
Reggie,
The J-Rod will give you more bang for your buck, because you will be able to mount a radio receiver in addition to your shock mount. You can also change shock mounts, which can not be done with the Rode.
Check it out !
Jeff Rhode is offline   Reply With Quote
Old February 21st, 2008, 09:47 AM   #6
Yes, thanks Kellen and Jeff.
I went ahead and quickly snagged a Rode mount, but I will *definitely* get a J-Rod for my (hopefully) second A1. (Actually, I may STILL get one for my first one -- I didn't think I'd need a receiver, but I might after all).
This is a great site -- Everyone is quite helpful.
Old February 22nd, 2008, 05:17 AM   #7
BTW Reggie :
Although very expensive, the Bebob box for under the camera works great for the firestore. It holds it still with cables out of the way, protects it, and keeps the weight under the camera to help balance it.
Check it out :
http://tinyurl.com/yulhtx
