If the G channel has more quality, then... at DVinfo.net
Old May 1st, 2008, 12:29 PM   #1
Hi, i have an idea! Is it good or is it stupid?
As the G channel has more quality in a HDV color space, then wouldn't be a good idea to shoot with a greenish dominance (using white balance or setting the camera parameters) and then in post re balance the colors in a 4:4:4 space?
Example: in this shot the R vs G vs G quality, noise and resolution are quite different.
Thanks for your advices.
If the G channel has more quality, then...-r.png   If the G channel has more quality, then...-g.png
Giovanni Speranza is offline   Reply With Quote
Old May 2nd, 2008, 02:20 AM   #2
It doesn't really work like that - if you try to sort the colours out in post, it takes the information from the relevant colour channel and therefore won't make any difference...or in the worst case won't look right as you can't balance it properly.
On a side note - this is the reason we use green screen for chromakey on video rather than blue as the green channel is a much higher quality and therefore easier to key out.
MBP 15" 2.6Ghz, 4GB RAM. 2TB storage. FCS2. Canon XH-A1.
www.jpcreativemedia.com vimeo.com/user449069
Jo Potts is offline   Reply With Quote
Old May 2nd, 2008, 06:45 AM   #3
Thank you Jo.
So is'nt there a way, using phase or any plugin that can apply the color of a channel to a different channel?
