A1 component to VGA converter at DVinfo.net
Old June 18th, 2008, 11:25 AM   #1
So, I'm wanting to hook up my A1 to my widescreen LCD monitor.
Would something like this work? http://www.bhphotovideo.com/c/produc...eries_VGA.html
Canon EOS 7D, Final Cut Studio 2
Brandon Freeman is offline   Reply With Quote
Old June 18th, 2008, 01:19 PM   #2
Images: 18
Hi Brandon...........
I'd give the input connectors on your screen a pretty serious scrute before thinking of buying anything.
The A1 outputs YPbPr Component @ 1920 X 1080 HD (OK, lets not do the 1440 looks like 1920 etc).
If you want to see that beautifull picture in all it's glory, you need a full 1080 screen with YPbPr Component inputs.
Many of the slightly older screens DO have VGA connectors, but to a man they severely limit the resolution and frame rate that they will accept (the picture looks horrible).
To make matters worse, the RGB of a VGA connector is NOT 1:1 compatible with the YPbPr standard (it might just work, but looks even worse than horrible, usually).
Back to the drawing board on this, I think.
CS
Old June 18th, 2008, 01:22 PM   #3
Does your monitor not have a DVI input?
Alex Plank is offline   Reply With Quote
Old June 18th, 2008, 02:11 PM   #4
My computer LCD monitor does have a DVI input... Can I do something with that?
Old June 18th, 2008, 02:37 PM   #5
well it'd be worth it to get a component to dvi converter instead of vga.
Old June 18th, 2008, 02:53 PM   #6
So, would this work?
http://store.a2zcable.com/vdc1-1-5.html
Or do I need something like this?
http://www.bhphotovideo.com/c/produc...Converter.html
Old June 18th, 2008, 03:08 PM   #7
Images: 18
Hi...
That first one is a NO.
The second one is a YES.
CS
Old June 19th, 2008, 04:10 PM   #8
Has anyone tried this box?
Component Video -> VGA
XCM 1080P VGABox
http://www.Extreme-Mods.com/XCM-1080...080pvgabox.htm
Dez Leung is offline   Reply With Quote
Old June 19th, 2008, 06:09 PM   #9
YPrPb has the sync signal embedded in the Y line, while VGA has separate H and V sync lines, so it is not possible just to use a cable for conversion (apart from the fact that the colour space is totally different). Here's a converter box that I found, but I haven't tried it myself.
http://www.ramelectronics.net/audio-...c11200-p1.html
Richard
Richard Hunter is offline   Reply With Quote
Old June 19th, 2008, 06:39 PM   #10
Images: 18
Hi.............
Dez:
The converter you posted would appear to solve everyones problems.
Talking of O/P'ing 1080p and all.
Sounds like the bees knees.
HOWEVER:
The kicker is this:-
I know of no screens which will run an I/P from said VGA connector above the VESA standard for WXGA resolution, which is............(drum roll)...............1360 X 768.
So, that adapter could put out 5000 X 4000 and it wouldn't mean a thing.
In order to get 1080i you need Component YPbPr (minimum)
In order to get 1080p you need either DVI or HDMI
(I know of no screens which will accept 1080p on the YPbPr connector, I'm not saying there aren't any, just that I am not aware of any).
The second unit Brandon posted in #6 is the way to go.
CS
Old June 19th, 2008, 09:23 PM   #11
Seeing as how that unit I posted is only $100 less than a 19" LCD HDTV at Walmart, I think I'll just pony up the extra mulah. Less stuff to carry around and power.
Old June 20th, 2008, 12:50 AM   #12
From Ebay, at only 49,95$
http://cgi.ebay.it/Component-Video-Y...d=p3286.c0.m14
Not tested!
Antonio Ricca is offline   Reply With Quote
Old June 20th, 2008, 12:58 AM   #13
Images: 18
Good find, Antonio........
Even better decision, Brandon.
CS
Chris Soucy is offline   Reply
