Canon XH A1 scene split problem at DVinfo.net
Old February 7th, 2009, 04:38 PM   #1
Hi all,
I use my Canon HV30 native files with Sony Vegas Video 8.0 c with no problems with automatic scene splinting, but with my Canon XH A1 it does not work, and all I get is a long m2t file. I donīt really know what is happening here or if there is any issue in this sense.
Any help from you would be very welcomed.
Thanks in advance.
Canon XH A1; Canon HV30; Nikon D300; Nikon D200; Sony Vegas Pro
http://www.juanparmenides.com
Juan Parmenides is offline   Reply With Quote
Old February 7th, 2009, 06:11 PM   #2
Images: 18
Hi Juan..............
Dive into your A1 menu and go to [Signal Setup].
Select the [Time Code] submenu, then [Count-Up].
What is it set for?
Vegas uses Time Code breaks to detect scene changes.
From my reading of the A1 manual, a setting of [Rec Run} only runs the time code clock when the camera is actually recording. This seems to infer that doing a Rec - Stop - Rec sequence doesn't force a time code break, as if recording stops, so does the time code clock.
Thus, by inference, to force a time code break you need a setting of [Free Run].
A subsequent Rec - Stop - Rec operation will create a distinct time code break, as the clock will have been running during the "Stop".
That's my story and I'm sticking to it.
CS
Old February 7th, 2009, 07:21 PM   #3
Scene change detection is based on time of day, not timecode. If the camera's date/time is not set properly, that could cause a problem with the scene detection.
Richard
Richard Hunter is offline   Reply With Quote
Old February 7th, 2009, 08:37 PM   #4
I think Chris has lost it. :D Listen to Richard
Old February 8th, 2009, 07:44 AM   #5
Wow, wonderful people, thanks. I īve never set the date (mea culpa) in the XH A1. Once I have done this, the scene split issue is fixed.
And.... is it worthwhile to spend HD tapes if I use a tape only once? I have made a test comparing two tapes , a normal vs an HD tape, and the quality, at least for me is the same.
I have used a Samung LCD TV full HD 1080 and I have not seen any difference.
Thanks again.
