XHA1 Tripod screw size at DVinfo.net
Old May 4th, 2009, 08:44 AM   #1
purchased a vinten tripod off of ebay however the screw that goes from the plate to the camera is too wide. What swidth screw should I be looking for?
Scott Millar is offline   Reply With Quote
Old May 4th, 2009, 09:05 AM   #2
Camera/ Tripod thread sizes.
There are 2 different size threads that are used on tripods and cameras. The larger one is 3/8-16 and the smaller one is 1/4-20.
Scott Dordick is offline   Reply With Quote
Old May 4th, 2009, 03:18 PM   #3
Images: 18
Hi Scott(s).......
If you're missing the 1/4" screw, screw/ pin plate and VHS pin assembly, don't despair.
(It sounds like you have the twin 3/8 screws instead)
E - mail:
Peter.Harman@VitecGroup.com
with a covering letter explaining the situation.
Peter is the Product Manager for Vinten, UK and can sort you out.
Let us know how you go.
CS
Old May 4th, 2009, 03:21 PM   #4
Contributor
Canon also sells a tripod adapter plate, the TA-100, that has both 3/8" and 1/4" threaded sockets on the bottom. However, there are probably other adapter plates that would be cheaper. This one is a quick release plate.
Here's something else:
http://www.bhphotovideo.com/c/produc...20_Tripod.html
Old May 6th, 2009, 03:35 AM   #5
Scott,
I also purchased a vinten a few months ago, that came with the 2 too wide screws.
I looked at purchasing the VHS pin adapter, but found it too expensive for a screw+pin.
What i did instead, i bought a few Manfrotto/Bogen 357 QR-adapter's, it was a lot cheaper then 1 vinten-plate and now i can switch my 2 camera's between all my devices (tripod, superclamp. glidetrack, time-laps-motormount, etc.)
Hubert Duijzer is offline   Reply
