Capture ProRes 1440x1080 or 1920x1080? at DVinfo.net
Old July 24th, 2009, 04:21 PM   #1
Hi guys
Just realised since I posted that there's just one capture setting relevant to me: HDV-Apple ProRes 422
My question is, for my XHA1 capturing into FCS2 via HDV-Apple ProRes 422, which of the following sequence presets will give me the best quality?
* Apple ProRes 422 1920x1080 50i 48 kHz
* Apple ProRes 422 1440x1080 50i 48 kHz
I'm concerned that if I use the wrong one, my resulting DVD might appear 'squashed' or something! :o)
Any thoughts would be really appreciated.
Peter
EDIT: I think I figured out that it's Apple ProRes 422 1440x1080 50i 48 kHz, because the item properties of the XH-A1 are 1440x1080 aren't they? So, the Sequence Settings much match the clip settings. I hope that's right anyway! :o)
Peter Dunphy is offline   Reply With Quote
Old August 1st, 2009, 02:48 AM   #2
Hey Peter.
The XH-A1 compresses the footage into 1440 by 1080 because it's a HDV camera so , i think you would probably bring the footage with it's original resolution , then you could stretch it in your NLE as desired.
hope it helped.
Arthur Abramov is offline   Reply With Quote
Old August 9th, 2009, 09:20 AM   #3
Peter,
1440 x 1080 works fine here - the new LT setting in FCS 3 is particularly good as it cuts storage and makes edit easier.
Strange though Log and Capture in '3 only gives a ProRes option with no further choices - it also generates inccorrectly formed files without a file type. A bug that will doubtless be fixed.
Nick.
Nick Wilcox-Brown, Film-maker and Photographer
https://nickwb.com https://wildphotographer.co.uk
Nick Wilcox-Brown is offline   Reply
