Stereo Mic with XH A1S at DVinfo.net
Old March 20th, 2010, 09:49 AM   #1
Can someone please tell me how they hook up a stereo mic to their XH A1S.?...using the XLR inputs.
I have a Audio Technica BP4029 I want to use. I'm not finding the info I need from the manual.
Any help would be appreciated.
Joe Cronin is offline   Reply With Quote
Old March 20th, 2010, 11:26 AM   #2
Go into the camera menu under audio settings. There will be two options for each channel L/R. You can change the channel input for both. Make sure each channel matches the XLR input on the camera. XLR Mic should be the setting.
If your mic requires phantom power then look on the front of the camera. There will be two switches there to enable phantom power for both channels.
Sylus Harrington is offline   Reply With Quote
Old March 20th, 2010, 01:31 PM   #3
Thanks Sylus....so then would you select XLR Rec Channel as CH1/CH2..?..seems obvious but it's confusing to me.
