-   Canon XH Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/)
-   -   XHA1 accessories questions (https://www.dvinfo.net/forum/canon-xh-series-hdv-camcorders/489027-xha1-accessories-questions.html)
Paul Elertson December 16th, 2010 08:14 PM
Hello all,
I will most likely be acquiring an xha1 this weekend and I'm looking into some accessories. (my first prosumer camcorder)
Background: The camcorder will mostly be used outdoors to film automotive racing events. It will also be used to film my upcoming wedding, but that will (hopefully!) be a one time thing.
Editing: Abode Premiere Pro CS3
What I do: Normally I film about 2-3 hours in one day, upload to my computer, and edit a 3-10min compilation video.
1) DTE hard drives. I really like the idea of copying files over since that is what I am use to. I also don't currently have a fire-wire input on my computer, not really a big problem to fix, but that is where im at right now. I've read conflicting things about use the xha1 to playback or rewind tapes, so that is also a concern.
The cheapest I could find was this one that records to a flash drive.
Shining Technology, Inc. - CitiDISK CFR - CitiDISK CFR
Pro's? Con's?
2) Microphone
Not sure if I should be looking for a stereo Microphone or a direction one?
This one has good reviews, but should I be looking for a direct XLR mic?
Any input is appreciated. Thanks!
Allan Black December 17th, 2010 04:07 PM
I'd make sure the person (not you I hope :) can run your A1 for your wedding, or let them use their own cam.
I'd fix the audio first ..
Low budget, yes the Rode Videomic. High budget .. the Rode NTG-3, both with their respective wind protectors. Then a B+W UV filter to protect the A1 lens. Have fun.
Cheers.
Paul Elertson December 18th, 2010 10:32 AM
Thanks for the reply.
Yes I am on a limited budget. The camcorder is coming with a UV filter :)
Any advice about DTE drives?
Battle Vaughan December 18th, 2010 12:13 PM
You'll need a good video tripod...and unfortunately, they aren't cheap. Fluid head, ball mount (for easy leveling). Cartoni and Sachtler are two quality but expensive brands....$1000 up ---
But --- I have had some experience with a Matthews M25 for less than $200 which, while having a lot of plastic on it, was the only cheap tripod (IME) that was worth looking at...held the XHa1 pretty well and is fairly lightweight.
I found the Canon wideangle adapter invaluable for the work I did with the XHa1 (News) but YMMV. A good shotgun ---Sennheiser ME66k6, Audio-Technica 897 or 875, Rode NTG3 (listed last, but is an excellent choice)...
Depending on your shooting, on and off-camera lighting gear --- LED panel for the camera... softboxes, or LED panels for area lighting, if you're going to do any kind of setup or interviews...and in that case, lavalier mike(s), wired or wireless...the camera, unfortunately, is just the beginning. They say audio is 70% of a video, so don't skimp on your mikes! Best wishes!
Taky Cheung December 18th, 2010 12:17 PM
I use NTG-1 with a 1 foot angled XLR cable. it looks so handsome on the Xh-A1. Check out some photos here
XH-A1s and XH-A1 Photos | L.A. Color Blog
Paul Elertson December 18th, 2010 05:44 PM
I only have a cheap tri-pod now and I'm looking into a better one. Thanks for the info
Agree on the audio comment. However, I am lucky in that audio for my videos is not quite as important since I am usually filming cars and not people.
Very nice! I know someone asked in your comments, but where did you get the 90degree adaptor?
Les Wilson December 18th, 2010 10:03 PM
Don't waste your money on a VideoMic. You have a real camera with a real mic mount. Get a real shotgun. The NTG-1 is nice and small. As mentioned, right angle coiled cable makes a nice tight kit.
The Libec Battle mentions is adequate. But plan to upgrade or get a good one from the start. I used an A1 with both NTG-1 and the Libec tripod.
Do a search on B&H for "right angle XLR coiled". Here:
http://www.bhphotovideo.com/c/search...tialSearch=yes
Battle Vaughan December 18th, 2010 11:25 PM
If you are at all handy with a soldering iron, it is easy to make your own custom mike cables to fit your camera; the XLR plugs (angled and straight) are available from such suppliers as Mouser (Mouser Electronics - Electronic Component Distributor) and Markertek (www.markertek.com), and quality audio cable as well. I made several such cables for the news crew I worked with before my retirement, was no chore to do...
Taky Cheung December 19th, 2010 11:43 AM
I got my 1 foot angled XLR cable at Audio Gear at Jack's Music Factory: Music Gear, Recording Studio Gear, Pro Audio Gear, Pro Audio Accessories*
Colin McDonald December 19th, 2010 04:00 PM
I'll second the Matthews M25 as an entry level tripod. It can cope with the XH-A1 with the W/A adaptor (a seriously heavy piece of glass!) and various other mounted accessories. The Matthews customer support is excellent as well.
Paul Elertson December 20th, 2010 11:18 AM
Just bought the camera yesterday! So excited.
http://www.boostedfilms.com/joomla/i...201280x768.jpg
Bill Watson December 20th, 2010 12:29 PM
Congratulations.I note you'll be doing a lot of outdoors filming. If so, do yourself a real favour and get a larger eyecup. I use the Sony one: http://www.dvinfo.net/forum/canon-xh...-eyecup-6.html
But I believe the eyecup on the new A1s is also good. At around $35.00 it's the cheapest upgrade accessory for this camera that I know.
Les Wilson December 20th, 2010 01:54 PM
Funny, I just took a break from cleaning up the studio where I found my i-Cuff for the A1. It's the Raider RAICUFFDV Raider i-cuff PRO Viewfinder Hood. It's strap has been customized with an inch of elastic to make it easier to put on and off the A1 eyepiece. I sold my A1.
It's yours for $20 including flat rat USPS shipping. Email me via DVInfo.
Larry Vaughn December 20th, 2010 02:49 PM
mic for XHA-1
I have a new in the box Rode NTG-3 mic with a case, clip, storage tube as it comes from the factory. I have more than one for my XH-A1 and some other shotguns, so I can sell this one if you are interested.
By the way, I also made my short right angled cable for the mic. I found some Neutrik right angled ends and used a cable I had.
The cheapest price on ebay today seems to be 614.99 so I will sell mine for $585 shipped.
Paul Elertson December 21st, 2010 10:44 AM
Thanks, I'll keep that in mind.
Thanks for the offer, but I will probably wait a bit and decide if I need one or not.
Thanks, but that is out of my price range. I will most likely get the NTG-1.
Les Wilson December 21st, 2010 04:22 PM
Note post #3 here: http://www.dvinfo.net/forum/canon-xh...mic-xh-a1.html
Battle Vaughan December 21st, 2010 06:31 PM
If I may suggest, look at the NTG2 rather than the NTG1, as for a small amount more it offers battery operation as well as phantom power, making it useful for other recorders or situations which don't provide the phantom power. NTG1 is phantom-only. I made that mistake once...
Les Wilson December 21st, 2010 08:41 PM
I had an NTG-2 for all the reasons Battle mentions. FOr me it was a mistake and I sold it then got an NTG-1. On the A1, I found the NTG-2 was too long. When pushed back, it gets in the way of the audio block and you hand. When mounted properly and with a dead cat, the hairs end up in frame. The extra length is also wobbly.
Battle Vaughan December 22nd, 2010 11:34 AM
Les has a good point, but there's a fix: my work camera had a Sennheiser ME66, which is fairly long. To move it back and up from the lens, I cobbled up an adjustable-position mike mount using pvc pipe and a Rode shockmount --- and then Rode came along and manufactured the same thing. I should have gotten a patent...anyway, here's a link:
http://www.bhphotovideo.com/c/product/463089-REG/Rode_SM5_SM5_Shotgun_Microphone.html
Allan Black December 22nd, 2010 07:07 PM
Battle .. merry Xmas from Rode :)
Cheers.
Battle Vaughan December 22nd, 2010 09:06 PM
Thank you, Allen, and Merry Christmas back at ya....Usual disclaimers apply to my comments, I have no connection with Rode but they make nice stuff at good prices in my experience...
