A1/G1 LCD/EVF accuracy.. curious...
does anyone know if the LCD of these cameras is a "what you see is what you get" kinda thing?
Reason i ask is that ive looked at many cameras, and the closest cam ive seen to have this ability is the DVX100b and the HVX.. even the 100a doesnt offer this type of accuracy.. without a field monitor were al gussing as to the actual saturation of what were seeing, as the LCD's usualy have a life of their own.. so how accurate are these units? for run and gun, i dont have the means to run tests or to mount an external monitor, so the LCD is basically needed to get the job done.. thoughts? |
Peter,
Adam Wilt's review in DV magazine states tha both the VFW and LCD display 100% vertically and crop a "few percent" horizontally. You can turn on guide lines that mark off safe areas. -Dan |
Certainly the LCD displays most of the recorded image. Like Dan says 100% top to bottom, and about 95-96% side to side.
However, it's quite a bit brighter than the recorded image - which is great when working outdoors in fairly bright sunlight - but it took me a while to work out why my footage was always coming out slightly underexposed! |
Now is there any way one can flatten the brightness to a neutral output, to offer the closest preview (in the EVF/LCD) to the actual output? I wasnt too impressed with the lack of audio tweakability.. heres hoping the LCD's can at least be tweaked... |
Concertina bellows hoods???
Is anyone familiar with this type of LCD bellows ?
http://www.canhamcameras.com/Bellows.html It appears to be a viable alternative to the usual velcro Hoodman type for the on-camera LCD and even the Marshall. |
Camcorder viewfinders and side-screens are WYSIWYG in the sense that you're seeing the image at taking aparture, at taking shutter speed and through all the menu tweaks (progressive scan, black stretch etc) that you've applied.
In film camera days viewfinders were much less informative, generally peeling off the image before the shutter and not showing you the aperture related depth of field. Of course projector masking was generally rather less severe than a lot of TVs, but screen masking was another matter entirely. I like the fact that now we see just what the chips are seeing, especially the DOF and effects of graduated filters at the taking aperture. tom. |
Bill |
You should also use the zebras to avoid overexposure, because this is all too easy to get if you just expose based on the average image brightness. Richard |
As for the Zebras, does the A1 allow for 2 readings simoultaneously.. well a range in fact.. ? Also does it allow for peak numbered readouts (like the DVX/HVX) reason i ask is that sometimes, Zebras actaully get in the way of the shot.. and seeing the exposure with a numbered readout is simetmes easier to manage.. |
Hi Peter. No you can't set a range of zebras, just a single value. And I haven't seen any mention of a numbered readout. Sounds like a nice feature.
Richard |
it is.. basically it removes teh zebra patterning on screen and replaces it with a point peak meter.. like a target of sorts.. which reads out the exposure level in percentages (much liek Zebras work in percentiles.. so does this.. ) the good thing about it as that you can see the exposure blow out as opposed to guessing it through the zebra itself.. sometimes u might WANT a shot to blow out.. (doing events, its a nice way to mess with live lighting situations.. )
| All times are GMT -6. The time now is 09:47 PM. |
