Bottom line flickers! It's driving me crazy at DVinfo.net
Old May 2nd, 2007, 12:24 PM   #1
Hi all, I've got an issue that if resolved would increase my happiness greatly. I have an XHA1 using Final Cut Pro and Compressor. Everytime I burn my footage to DVD (using DVDSP) and play it back on a normal TV the bottom line of the video flickers. My videos are shot in 16:9 so the bottom line of the video is visible. It's not too bad so I doubt if my clients really care, but it annoys the hell out of me! Here's my workflow thus far:
1. apply deinterlace filter in FCP to all video
2. render and export as mov dv ntsc
3. use compressor to make m2v files (best DVD setting 4:3, 90 min)
4. burn disc with DVDSP
I've also tried, deinterlacing in compressor, changing the upper and odd things for the deinterlacing methods in final cut and compressor
Any help would be fantastic, because I'm so new at all this, and I don't know anyone that knows anything about this stuff. Thanks.
Josh Green is offline   Reply With Quote
Old May 2nd, 2007, 01:59 PM   #2
Why are you deinterlacing? That most likely is your problem right there. If you want progressive scan, shoot progressive scan, if you want interlaced shoot interlaced.
Stefan Scherperel
SSE Productions
http://www.stefweb.net
Stefan Scherperel is offline   Reply With Quote
Old May 2nd, 2007, 02:34 PM   #3
deinterlacing
If I don't deinterlace, the video is way to stroby, and my camera won't shoot true progressive video or I would be all over it. My videos are almost entirely slow mo too, not sure if that makes a difference but I think it does.
Old May 2nd, 2007, 04:42 PM   #4
The XH-A1 will shoot true progressive!
Old May 2nd, 2007, 05:25 PM   #5
Did you try playing the DVD on another TV ?
If the TV vertical offset is not working right you could end up with this problem.
Gert Kracht is offline   Reply With Quote
Old May 2nd, 2007, 06:08 PM   #6
Why aren't you shooting 60i, then conforming to 24p in cinema tools?
Steve Yager is offline   Reply With Quote
Old May 2nd, 2007, 06:21 PM   #7
all i know
all i know is that when i shoot in 30f the slow mo looks way worse. I always shoot 60i and use a natress's g 50% slow mo filter to split the fields and make it look smooth. How do i conform the video to 24p?
Old May 2nd, 2007, 06:23 PM   #8
use the cinema tools app that came with FC Studio. Do you have that or are you working on an older version of FCP, or a "borrowed" copy?
Old May 2nd, 2007, 06:55 PM   #9
i have it
I have cinema tools but cannot figure out how to do the conform everyone speaks of. do I capture into cineform?
Old May 2nd, 2007, 06:59 PM   #10
Just import the clip you want to conform (overcrank) and then click the "conform" button on cinema tools and specify the fps.
Old May 3rd, 2007, 05:20 AM   #11
Hi Josh,
I'm having the EXACT same problem as you, and still have not found out whay it's happening. Like you, i also use Final Cut Pro, and shoot in 16:9 in standard DV. I run off MPEG2 not using compressor though, and then complete the DVD through DVDSP.
I've noticed that with the slow motion transitions it is particularly bad, and i also do some split screen stuff and it really shows up. It is quite visible when you play back in Final Cut Canvas, so i don't know if it's a capture problem or a software thing with Final Cut.
As far as the de-interlace, i only use that on still images used in the DVD.
If you find out why it's happening please let me know, as it's bugging the hell out of me too, and so far clients haven't spotted it, but it's only a matter of time before someone does complain about it.
Martin Trotter is offline   Reply With Quote
Old May 7th, 2007, 04:25 AM   #12
Have you found anything out yet Josh?
Old May 7th, 2007, 07:58 AM   #13
The fluttering top or bottom line of letterboxed video is an artifact of the editing, compression, or monitor/display system, not the camcorder.
I've run into it when masking SD 4:3 footage in Premiere to give it a letterboxed look (for folks who want 16x9 wideangle look). But I've not yet made the effort to determine the specific source.
dpalomaki@dspalomaki.com
Old May 7th, 2007, 09:38 AM   #14
Not a FCP user, but the way I conform 60i to 24P slow motion is the following.
Open the 60i footage in a 720P 60fps timeline
Render the footage as a 720P 60fps file
Bring the 720 60fps file into a 24P timeline
Slow the 720 60fps footage to 40% original speed.
Result= perfect slow motion footage.
you can see some of the results of this in the following trailer shot with the A1.
http://www.stefweb.net/mantoman/Trailer%20TEST%205.wmv
Stefan Scherperel
SSE Productions
Old May 7th, 2007, 04:58 PM   #15
that trailer looks fantastic - - a little off topic but are you using a 35m adaptor on the A1? And do you shoot everything in 60i and then convert to 24P?
trish
Trish Kerr is offline   Reply
