XL2 AE Shift vs Gain at DVinfo.net
Old November 27th, 2007, 10:28 AM   #1
Can someone in a simple way explain to me the differences in Gain and AE shift. Through my first 5 weeks of tinkering with the Camera I have left my AE shift on "0".
I know the gain knob can add alot of noise when I start adding some light. What does the AE shift do? and when should I use it?
Guy Godwin is offline   Reply With Quote
Old November 27th, 2007, 01:35 PM   #2
Guy-
This may help.
http://dvinfo.net/conf/showthread.php?t=74676
Tim Bickford
Tim Bickford is offline   Reply With Quote
Old November 27th, 2007, 05:24 PM   #3
Simple answer: the AE shift is for those times the auto exposure doesn't give the correct exposure for certain conditions, like when shooting into a strong backlight behind your subject. The camera will expose for the backlight, so the subject will be dark. Use the AE shift on one of the + settings so the camera "overexposes," so the subject will come up lighter.
AE shift is for any time you're working under conditions that cause the camera to over- or underexpose consistently. It lets you "tweak" the auto exposure.
Gain is simply like turning up the volume on your stereo, only for the video signal. I don't know how long you've had your camera, but for me, the Auto gain setting was one of the first things I turned off. Too many times it cranked the gain high enough to where it looked like I was shooting through a pink snowstorm (noise). I usually keep it at 0 or +3. The only time I go higher is for very low-light shooting, like street festivals.
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply
