SMPTE Timecode on XL2 - Page 2 at DVinfo.net
Old July 13th, 2004, 01:12 PM   #16
Right, and a bit pointless I guess since DV records audio on the tape. External audio, though, with the XL2 having internal SMPTE time code... should match up seemlessly without needing the visual referance the slate. Correct? Just thinking about for when we'd use them, more seemlessly integrating these cameras in to our usual production habbits.
Holly Miller is offline   Reply With Quote
Old July 14th, 2004, 08:33 AM   #17
TC out to TS-3 Slate
This piece of gear should give you what you want. It simply plugs into the Lanc jack and extracts the code outputting to an external device such as the Denecke slate. You were confined to drop frame only with the XL-1/s but the XL-2 adjustable code changes everything. I have found that reality show producers like the DV cameras with time of day / reel number capability because of the ease of logging tapes in post.
www.spcomms.com/ltcexport
James Emory is offline   Reply With Quote
Old August 1st, 2004, 07:02 AM   #18
RED Code Chef
Sounds interesting James. Any idea what such a device would cost?
Rob Lohman, visuar@iname.com
Old August 1st, 2004, 07:52 PM   #19
I believe this item costs around 250.00
