XL2 lens barrel movement at DVinfo.net
Old April 30th, 2010, 05:56 PM   #1
I just bought a used XL2 and when the lens is in the locked position there is some slight movement. I this normal?
Ed Space
uwrite
Ed Space is offline   Reply With Quote
Old April 30th, 2010, 07:27 PM   #2
Images: 18
Hi Ed.................
On my XL1s there is some very slight movement, both rotational to the lock and back again (but I do mean minute) and lateral as the lens mount is flexed from side to side (again, minute).
If yours' is any more than that I would dismount the lens and ensure that the screws holding the lens mount ring onto the camera body are full fastened and that the screws holding the mating part onto the rear of the lens are ditto.
You'll need a jewelers screw driver kit as both sets of screws are miniscule.
CS
Old May 1st, 2010, 05:49 PM   #3
XL2 lens movement
Hi Chris,
Sounds like my problem. When locked there is some slight "play" in the lens barrell up or down, side to side. Probably less than 1/16 inch at the end of the lens. Disconcerting when you reach up to the focus ring and feel this slight "wiggle". I'll try your suggestion. Thanks Chris,
Ed
uwrite
Old May 1st, 2010, 06:28 PM   #4
Ed, I have to agree with Chris. I have a XL2 and the movment of the lens on the camera is very small, you can feel it but you can not see it. I vaguely remember this subject cooming up before on the XL2.
Terry
Terry Shaw is offline   Reply With Quote
Old May 2nd, 2010, 12:11 AM   #5
XL2 lens barrell movement
You'r right Terry. I looked up some old threads and this is nothing new to XL2s. I tried Chris's fix and found the culprrit to be the body lens mount ring but I could not tighten the screws any, suggesting the taps are stripped. Probably could be repaired but I think I'll return the camera. Thanks Terry,
Ed
uwrite
Old May 2nd, 2010, 01:20 AM   #6
Images: 18
Bugger.............
Isn't it a sod when someone flogs you gear as good when it's obviously damaged?
Sorry Ed, for your sake.
Sounds like it's taken a tumble and, as you say, stripped the mounting screws.
Hope the return works out OK.
CS
Old May 2nd, 2010, 02:42 PM   #7
Thanks Chris, I think I'm going to be OK. The seller is a reputable ebay dealer.
Ed
uwrite
Old May 3rd, 2010, 07:07 PM   #8
Hi Ed,
Sorry to hear that you could not fix the mount yourself. I hope all goes well with the return.
Terry
Old May 4th, 2010, 01:33 AM   #9
XL2 Lens barrell movement
Thanks Terry, I'll be OK, the seller is a reputable ebay store, Adorama. This is the second XL2 they sent me. The first one had a loose viewfinder. Does anyone look B/4 shipping? I'm beginning to wonder about buying used, but hesitate to buy new SD that is phasing out. How much future is there for XL2 SD, Terry.
Ed
uwrite
Old May 4th, 2010, 02:34 AM   #10
Images: 18
Well, can't answer for Terry, but it's got quite a few miles in it yet (IMHO).
There's still a shed load of stuff being shot in SD and will be for the next 5 years, at least.
It needs to be shot in 16:9 of course, which the XL2 is, and gives a pretty good picture, nothing by HD standards, but decent SD at least.
Don't write it off, it's got more legs than you can imagine. Long after the "First" world has gone HD, a great deal of the planet will be faaaaaaar behind.
And the "First World" still hasn't got it's head entirely around HD, heck, how many VCR's are still out there?
VCR = SD, end of story.
It's (HD) growing, but it's going to take years for all this legacy stuff to work it's way out of "the system".
Don't rush it, it will happen whan it's appropriate.
Get another XL2 and go for it.
Better a decent film shot on an XL2 than a complete load of b****cks shot in HiDef.
Just my take.
CS
Old May 4th, 2010, 04:19 PM   #11
Thanks Chris. I tend to agree with you. To replace the features of the rugged XL2 with a HD camera, is in the $5 to $6 K range. Especially the interchangable lens. I have a Canon 16X W/A that's my work horse on the XL1s. Time to move up to the XL2, new or used.
ED
uwrite
Old May 4th, 2010, 11:48 PM   #12
Hi Ed,
I have to agree with Chris. I think it will be may more years before it's time to put the XL2 on the shelf for good. It all come down to what you plan on using it fore. If you will not be burning to Blueray or doing much work in Hidef then the XL2 will serve you well. If my XL2 bit the big one I would probably buy another new one.
Terry
Old May 5th, 2010, 09:19 PM   #13
Thanks Terry,
You XL2 users are a stubborn, faithfull bunch. I will get a new or used XL2 after I see what Adorama offers me. I see I said 16X W/A in last post, should be 3X,
Ed
uwrite
