focus problem
I am shooting with the XL2 with the 20X lens. Mostly of eagles setting in trees. I'm shooting in manual mode with manual focus. Bright sun light using ND set at max, 30 fps and shutter at 1/60th.
The problem is the focus keeps going in and out slightly, just enough to make the footage useless. In auto focus I could understand but in manual focus, even when I set the focus it will go in and out of focus slightly. Thanks for any help. Warren |
Do you mean that providing the subject you are filming remains in the same place all the time, the focus drifts out in manual mode? If so, there must be definitely something wrong with your camera.
Is it possible you are hitting the focus ring by accident? With hand or piece of equipment? |
Are you absolutely sure it's not an atmospheric effect? You did mention bright sunlight.
Hi, Warren...........
With the shutter tacked to 1/60, my guess, and that's entirely what it is, is that the apeture is wandering around based on subject matter, changes in light levels etc (and with the ND's maxed out as well, the changes could be quite significant).
With the change in apeture, there will be a significant change in DOF, so that something that was apparently tack sharp at f8 goes soft at f3.5, say. [That 20X lens is incredibly sensitive to DOF even at 700 metres, which is one heck of a long way]. This would give the effect you're describing. For such pinpoint shooting where the DOF MUST stay where it's put, I can't see any way around it but to switch to 60i, tack the apeture to say, 5.6 and let the shutter speed do the walking. That's my standard shooting mode with my A1, and I don't get the problem you have described. Make any sense? CS |
#5 |
Trees do sway, enough to affect critical focus at long lengths and wide apertures, and you get atmospheric distortion as Colin suggested. If you need the wide apertures not much you can do, it's a compromise, but otherwise stopping down helps. I do have some suspicions that the inbuilt NDs tend to soften things, as does any extra glass in front of your lens. Why shoot at 1/60 in bright sunlight? If this is an attempt to get a film look, you might need to know that higher end film cameras (and lower end like the Bolex H16 which was the wildlife staple) had (and have) variable shutters and it wasn't (and isn't) unusual to shoot equivalent to around 1/120 in daylight. No-one complained that it looked unnatural or didn't look like film. You do want locked exposures and shutter and unless you want to do half res slo-mo 60i is a really bad idea.
#6 |
Focus Problem
Thanks guys for the replys.
I'm going to try your suggestions. Shooting with a higher shutter speed and also try setting the Av at 5.6 or 6.3 and letting the shutter done what it needs to do. After looking at my clips again I now believe this may be atmospheric effect. I'm shooting over a wide stream at these birds. I also shoot them setting on ice at the edge of the water and I think it's mostly atmospheric effect. I'll be back out again tomorrow and give it another try. Thanks again, Warren |
#7 |
Let us know how it worked out.
dpalomaki@dspalomaki.com |
