XL2,FS-4 and Firewire at DVinfo.net
Old June 2nd, 2013, 05:09 AM   #1
Hello.
Right I wanted to transfer the files from my Firestore FS-4 Pro to my laptop.
FS-4 is 6 pin Firewire laptop not got Firewire so I thought a Firewire to usb adapter would be ok.
Bad move it looks like it has blown the port on the FS-4.
So need to get it repaired to another FS-4.
Looking for a new laptop with a big HD, none have Firewire or cardbus ( none that I can afford )
Seen a couple with 4 pin Firewire on them, so can I use a 6 pin to 4 pin cable between the FS-4 and laptop or does the FS-4 need the other 2 pins to work?
Thank you for any help
Brian
Brian Kilford is offline   Reply With Quote
Old June 2nd, 2013, 08:13 AM   #2
Re: XL2,FS-4 and Firewire
I think it should work with the 6-pin to 4-pin cable. The FS-4 is self-powered, so that would tend to point to not needing the other 2 pins (device power) and also the FS-4 comes boxed with two firewire cables, both of them 6-pin to 4-pin.
The manual makes reference to connecting the FS-4 to the computer using a 6-pin to 6-pin cable, which I think is not totally accurate. If for some reason it really does require 6-pin to 6-pin and you connect it up with a 6-pin to 4-pin cable instead, I believe you can't do any harm to either the laptop or FS-4, it just won't perform the data transfer. Just make sure you have a charged battery or have the FS-4 on AC power.
A good precaution to take with firewire is to only connect and disconnect the cable while the equipment is not powered on.
P.S. - - I see the HP ProBook 6360b laptop going for $680 USD and has a firewire port.
Old June 2nd, 2013, 09:34 AM   #3
Hello Mark
Thank you for your reply.
Very helpful, I have found a few laptops that have express card ports so I could have Firewire ports on them.
That would eliminate any possible problems.
Thank you again.
Brian
