Shotgun mic replacement for stock? at DVinfo.net
Old January 29th, 2006, 11:56 AM   #1
Is there a small shotgun mic that I can directly replace the stock mic on my XL2 for?
Adam Bray is offline   Reply With Quote
Old January 29th, 2006, 11:40 PM   #2
You could stick most any shotgun in the mount and plug it into the XLRs in the back. I've stuck my Sennheiser MKH60 and my ME66 in the mount more than a few times and shot just like that. I did stick some foam padding in the mount to hold the mic tightly. Works fine. They do make shock mounts that clip onto your camera to dampen the handling noise. I would suggest one if you are doing critical audio recording.
Joe Winchester is offline   Reply With Quote
Old January 29th, 2006, 11:41 PM   #3
Oh, and remember, your stock mic is stereo, and shotguns are mono. So it wouldn't technically 'replace' your stock mic. Just a note.
Old January 30th, 2006, 04:55 AM   #4
Audio Tehcnica offers several models at a somewhat lower price point than the Sennheiser, and below that are several Azdens and others. Probably best to avoid the under $150 models, and be sure it has an output impedance of around 600 ohms or lower, otherwise you may have significant output loss due to impedance missmatch.
dpalomaki@dspalomaki.com
Old January 30th, 2006, 10:51 AM   #5
How is the ME66 powered?
Old January 30th, 2006, 11:13 AM   #6
me66
with the K6P module you can use both phantom and 1 AA. I have used both with no diffrence in audio quality or camera runtime (not a noticeable tax).
Frank Moss
nine 13 media
http://nine13media.net/
Frank Moss is offline   Reply
